Hi All, I'm in a little bit of a sticky situation, so if anyone could help i would appreicate massively.
So, I have bought a Custom Mini Pc, With room to add a 2.5 inch laptop drive. I have a NVME in it for main OS and it didn't come with the HDD mount to add my 2.5 inch drive. It has the sata connection port. The only idea i have had is to somehow Mount it to the roof of inside of the mini pc (The roof of the mini PC is plastic).
As i understand, HDD vibrates alot, so sticky pads of any sort would not work since over time it will eventually drop, and thus cause damage to the board.
However, I have had an idea to get a random plastic HDD mount from anywhere, and use plastic bond to bond it to the roof of the inside of the mini pc, Even this though, i am uncertain it will work.
I have attached an image of the location I am thinking to somehow secure a plastic HHD mount, however i don’t want to drill holes through the lid. This is the only place it can fit.
If anybody has any idea on the best way I can do this would be hugely appreciated. Thank you for reading.
