missing 12v cable from emermax 535 what to do?
mihasya
84
i am missing a 12v cable from my emermax that i just got, what da heck am i supposed to do? its for the DFI lanparty Ultra-D NF4 board which requires3 power connectors ATX, 12v and 5v/12v. the 12v is the 4 slot square connector. anybody?
Missing a 12v cable? Does your PSU have a 20-pin ATX connector? If true, either purchase a 24/20 - pin adapter or purchase a PSU with support for a 24-pin ATX interface. Unless your taxing the PCI-E with a video card or another process-intensive load on that line, you don't need the 12V connector. If this system sounds like yours, purchase an adapter and make sure your PSU is up to snuff, as only the first 20 pins provide power. If not, I recommend a newer PSU, innately supporting 24-pins out of the box. I'm probable some people might argue that a old monster quality PSU could support the latest and greatest PCIe graphic cards, but this is my recommendation; so, please feel free to absorb other advice.
I got the 535 for a temp PSU a little while ago. It's actually an EPS spec PSU, there should definitely be an 8pin to 4pin adapter in the box, if not I'd take it back. And btw, I'd definitely use <b>all 4</b> connectors for the DFI board.
Erm...if it's not there, and it's supposed to be...RMA.
If it...broke off...then that's something else. I have the 535 whisper II, is that the one you're talking about?
F@H:
AMD: [64 3000+ (down)][2500+][2400+][2000+][1.3][366]
Intel: [X 3.0x3][X 2.8x2][P4 3.0x2][P4-M 2.4][P4 1.4x5][P4 1.3]
"...and i'm not gay" RX8 -Greatest Quote of ALL Time
It was missing from box, i had to get another one. Its all good now, was panicking trying to figure out what da heck i was missing for a while, then started reading all my manuals thoroughly and found i was missing a processor power to 12v adapter.<A HREF="http://www.crazypc.com/images/powersupply/eg565/allin1cablebig.jpg" target="_new">Clicky</A>
-thanks
<P ID="edit"><FONT SIZE=-1><EM>Edited by mihasya on 09/06/05 04:06 PM.</EM></FONT></P>
