So i recently bought a a Antec 902 case for my new rig i also bought a COOL MASTER hyper 212+ cpu cooler for my 17 930
I also have a Gtx 470 wich gets hellla hot and i want to add the 120mm fan on the side vent for another intake fan as it will blow directly on the video card
but here is where my problem lies if you look at the first link at the top corner of the fan slot the CPU cooler has those little gold things sticking out into the tip top portion of where the fan would go you can click the second link and see what im talking about
So my question is can i modify a 120mm fan to fit in there like can i just saw off that top corner since it doesn't need to be drilled into place its being held by clamps that are on the case
Could anyone offer any suggestion and a good 120mm fan that isnt very loud but provided good cooling id greatly apprecaite it tHANKS !
http://images02.olx.com.ph/ui/4/72/04/67766804_2-Pictures-of-VERY-REASONABLY-PRICED-ANTEC-902-ADVANCED-GAMING-CASECASEONLY-RETAIL-PRICE-IS-P7200.jpg
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=35-103-065-S01&SCList=35-103-065-S01,35-103-065-S02,35-103-065-S03,35-103-065-S04,35-103-065-S05&S7ImageFlag=2&Item=N82E16835103065&Depa=0&WaterMark=1&Description=COOLER%20MASTER%20Hyper%20212%20Plus%20Intel%20Core%20i5%20%26%20Intel%20Core%20i7%20compatible%20RR-B10-212P-G1%20120mm%20%22heatpipe%20direct%20contact%22%20Long%20life%20sleeve%20CPU%20Cooler
