Monitor has jaundice!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My monitor has suddenly acquired a yellowish cast to it's hue. Sony
GDM-500PS 21" connected to Leadtek A380 5950 Ultra video card with BNC
cables - been working like a charm for about 6 years now.
Flickering between good color balance and yellowish started yesterday
and no amount of re-installing drivers (using Driver Cleaner 3 in
between) has made a difference.
Have adjusted refresh rate, imported color profiles, etc. and am puzzled.
Ideas?
Cable problem???
Check all your cables, simce one may be loose.
"Steve Marshall" <marshall22@mindspring.com> wrote in message
news:%23$k8dpCwEHA.824@TK2MSFTNGP11.phx.gbl...
> Flickering between good color balance and yellowish started yesterday and
> no amount of re-installing drivers (using Driver Cleaner 3 in between) has
> made a difference.
> Ideas?
Yves Leclerc wrote:
> Cable problem???
>>made a difference.
>>Ideas?
Yves,
Thanks. I think that may have been the problem - disconnected and
reconnected all BNC cables and on video card - problem solved.
I was shuddering to think that I needed to replace this monitor - high
quality, high refresh rate, low dot pitch 21"-22" CRT monitors are still
very expensive.
Steve
Dying gun in the Cathode Ray Tube (CRT)! It "is" 6 years old!
Regards:
Richard Urban
aka Crusty (-: Old B@stard 🙂
> made a difference.
> Ideas?
It is more often a cable problem FIRST! If not the cable then we check
video card /drivers. If still not fixed, then it is the monitor.
I am glad you solved your problem.
Y.
news:e6gSpKDwEHA.3896@TK2MSFTNGP09.phx.gbl...
> Yves Leclerc wrote:
>> Cable problem???
>>>Ideas?
> Yves,
> very expensive.
> Steve
