Not sure if this belongs under Displays, but frankly, I have no idea what the problem component is at this point, so this section seems most apt.
As of a week ago, I have been experiencing an issue where my PC successfully boots to Windows 10, but the monitor cannot connect to HDMI. I tried switching cables - didn't work. I got new cables - didn't work. I tested three separate monitors, also didn't work. I tried multiple ports on the GPU and monitors in case one was dead - didn't work. I tried to connect using the iGPU - didn't work. I have only been able to fix the issue once, by unplugging the PC. Afterwards, the monitor recognized the HDMI cable. I have been running this driver version long enough that I know it to be stable, and have had this PC and GPU for a fairly long time, but not long enough to expect issues like this.
The problem has popped up again, and unplugging no longer produces results. Uhh... help, please. I'm at a loss, I've tried literally everything I can think of, save for using a DVI cable, since I don't have one. If this is some HDCP issue, I'm swearing off HDMI forever, because what the hell is this.
