Question Monitor shows weird lines at high refresh rates with solid blue and orange.
Nov 7, 2021
7
i have an MSI G271 and any time i look at solid blue or orange i can make out faint but distinctive faint white lines, this effect lessens at 60 hz and is most prevalent at 144 hz. Its incredibly annoying. I want to fix it.
Is this an issue with drivers or is it a faulty ips panel?
You might want to take the panel over to a donor system and see if the issue crops up on said donor system. have you tried working with different cables and inputs? How is the monitor tethered to your platform? What resolution are you working with while on 144Hz? What GPU are you working with? Make and model of your PSU and it's age? Make and model of your motherboard and it's BIOS version? OS?
