Hey everyone, so I've been having issues with my ll120 fans that are directly connected through my motherboards system fan headers while another two ll120 fans are connected to a separate header that is not related to the motherboard, however they also power system fans. My problem is that the 2 fans connected to the separate hub work perfectly fine meaning not flickering or freezing, however the the other 4 fans that are connected directly through the fan headers (one connected to the cpu fan header) of my motherboard flicker and freeze when trying to perform their light animations through the ICUE Software. Is there any way to somehow prevent the fans that are connected to the motherboard from flickering because if the separate header doesn't make the fans flicker or freeze, then my only guess is that the motherboard doesn't provide enough power to each header for my fans hence why they flicker with a white light.
Motherboard: MSI MPG Z390 Gaming Edge AC
CPU: Intel i5 9600k
RAM: Corsair Vengeance Pro RGB 16gb (2x8)
GPU: MSI GTX 1050ti Gaming X 4gb
SSD: SAMSUNG 860 evo 500gb
PSU: Rosewill, Photon, 750 watts 80+ Gold, 1 month old, practically new.
Thank You!!
CPU: Intel i5 9600k
Thank You!!
