The head doesn't fit the hole in shroud ? By how much ? You can always file or sand it a bit to be smaller, difference can't be great.Same issue as this post, motherboard screw works with standoff but won't fit into the shroud.
Info
Motherboard - NZXT N7 Z490
Case - Cooler master CMP 510
I'm using the screws that came with the case as there were no screws included with the motherboard.
Pretty big difference. I opted to order new screws. Thanks for the reply!The head doesn't fit the hole in shroud ? By how much ? You can always file or sand it a bit to be smaller, difference can't be great.
