My computer recently received a windows blue screen that restarts in a loop. The stop code is Session 1 Initialization failure, I tried all the troubleshoot options including entering various commands through command prompt but to no avail. Therefore, I decided to reinstall Windows 10 iso through a 32GB USB and boot it through Rufus using partition MBR and format NTFS including adding the fix for older BIOSes. When I select any boot first device from the menu it doesn't seem that the motherboard recognizes the USB. I also tried all of the fixes found on this url https://www.blackmoreops.com/2013/12/28/enable-usb-boot-in-gigabyte-motherboard/ any help would be enormously appreciated since I have exhausted all of my options. My motherboard is GA-78LMT-S2
Thank you
Thank you
