Hello!
I've been having these issues for the last 2 weeks where my mouse disconnect and then reconnects (1-8 seconds). Sometimes you here the windows sound of connecting hardware, sometimes you don't. It is not the mouse that is faulty because I've tried it on a friends computer without any issues, I have also tried other mice on my own with the same issues. However the mouse I mainly use, a Logitech G9, does seem to disconnect more often than my much older Logitech MX300.
I've been looking around the web and read several threads about similar issues. But none of them seem to have actuelly solved it.
I have tried uninstalling all the software from Logitech (Setpoint), no luck there. Someone gave the tip of uninstalling the drivers from Control Panel>Mouse>properties etc.. No luck there. I have disabled the function that can turn of the mouse for energy saving purposes. No luck there. I've been into the Registry and cleaned out some Logitech Setpoint entries that I could find (possible I've missed some). So now I can't think of anything else to try. I'd prefer to NOT have to reformat.
I did also just try to plug in my screen usb-hub on my Samsung 2493HM in case that might have had it's own power supply. But that didn't do any difference.
Something I could mention is that there was a Windows update on the 31 of october that updated "Realtek driver update for Realtek PCIe GBE Family Controller". And my problems started occuring a couple of days after this I believe.
I hope there are some wise people out there that can help me
Kind Regards
Andreas
My system:
Microsoft Windows 7 Home Premium 64-bit
Intel i7 920
Asus P6T SE
2x WD Black 500GB
1000W PSU
Asus Nvidia 280GTX
6 GB Kingston HyperX
Kind Regards
Andreas
My system:
Intel i7 920
Asus P6T SE
2x WD Black 500GB
1000W PSU
Asus Nvidia 280GTX
