[SOLVED] MSI - B250M MORTAR Micro ATX LGA1151 Motherboard has an onboard USB 3.0 header, but the Cooler Master - Elite 342 (Black) MicroATX Mini Tower Case w/4
Mar 18, 2019
14
its like the title
MSI - B250M MORTAR Micro ATX LGA1151 Motherboard has an onboard USB 3.0 header, but the Cooler Master - Elite 342 (Black) MicroATX Mini Tower Case w/400 W Power Supply does not have front panel USB 3.0 ports.
but if we dont wont to use the usb 3.0 can we so still use the case?
So you're saying the case only has usb 2.0, you can use the case without the front usb, but the usb on the front wont work. You can also but a usb 2 to usb 3 header adapter if you do want to use the front usb.
