Question MSI B450M MORTAR TITANIUM - problems with USB-drive
Oct 22, 2019
Hello.
I bought a new custom built computer a few months ago. It has worked perfectly fine until I tried to connect a USB-drive to it yesterday. The USB-stick that has worked fine on all of my other computers doesn't get recognized by the system. Nither in the file explorer or in the device manager.
I have tried to update the drivers to the USB-stick, tried diffrent ports on the computer, changed the stick out, but nothing has helped.
My knowledge inside of BIOS is limited but I think the problem might have to do with a bad BIOS update.
What do you think? Has anyone got the same problem as I do, or do you know a fix? Please let me know. I really need to use my stick in a few days!
Have a good one!
It doesn't seem that your USB ports are bad. Try using other USB devices like external harddrive and Thumb drive. If it doesn't work then try re-installing the USB device drivers. but if other external devices runs through the USB then the USB stick might be defective.
I have tried to connect the thumbdrive to other computers and it works perfectly fine. But I gave you some wrong information in the first text. The device get recognized in device manneger but it has this yellow triangel in the top corner. I have updated the drivers to that stick but cannot get it to work.
