MSI GTX650 POWER EDITION OVERCLOCK 1GB VS MSI HD7770 OVERCLOCK 1GB
Your post and your subject is misleading. But I'm guessing your refering to 650 Ti. if that's the case, I would ask if they have the same price. If so, I would go with 650 Ti. Because it is better and realistically best at that price range.
http://www.techspot.com/review/603-best-graphics-cards/page12.html
I wouldn't suggest you more expensive card because I guess your on budget. So I would go with 650 Ti if I were you.
Sorry was just a normal 650 not sure why i messed the title and message up
Core/Memory
1124MHz Core
1024MB GDDR5 5000MHz Memory
Video Output Function
Dual-link DVI-I x 1
Dual-link DVI-D x 1
Mini HDMI x 1
is the specs of the 650 (no ti) whatever that is
If you follow this one as I've tried to backread some threads, http://www.tomshardware.com/reviews/geforce-gtx-660-geforce-gtx-650-benchmark,3297-24.html. You could see the 7770 is over 650. But I couldn't find benches of games that you listed, So i checked a almost similar game, FC2. http://www.guru3d.com/articles_pages/geforce_gtx_650_msi_power_edition_review,11.html. 650 only wins by a small margin. But 7770 wins in other games by small to huge margin. So basically 7770 is the better card.
if its gtx 650 non Ti then blindly go for hd7770 and if you are on tight budget then go for hd7750, use sapphire trix and set Board Power Li to 20 and see the magic!!
can i do whatever this means to a 7770?
