Good day,
My MSI Pulse GL66 laptop isn't starting up anymore. I have changed the processor voltage offset by -70 and it worked perfectly and fine.
I then read that the ring/cache offset should also be changed to the same value. I restarted my laptop and changed this as well within the bios, however, since then it doesn't start up anymore, the power button only flickers orange and white.
I didn't want to open the laptop by removing screws as it might void warranty or break factory seal. So all I have tried so far was to:
-Turn off laptop
-Remove AC adaptor
-tried clearing CMOS by inserting a pin on the backside
-couldn't turn laptop on again, unless I plugged in AC adapter.
-plugged it in and turned it on
-same problem persists, black screen with orange and white light going on and off.
Any recommendations? Or help to what I can do
-Turn off laptop
-Remove AC adaptor
