Question MSI Z270 A Pro MoBo and RGB Fans
grungefadedn94
6
Is it possible to connect a set of 3 corsair LL120 RGB fans to a MSI z270A Pro? My friend gave us his old fans and I really want to hook them up to my motherboard but Im reading that the z270 a pro has no RGB header? Any other way around connecting these fans to my PC?
You can connect the RGB fans to the RGB lighting hub and then run the power off the PSU. The fans can then be plugged into the board with their PWM fan connectors/headers. If you do connect the fans using only the PWM headers, the fans will work but without the RGB fan hub.
