Hi All,
For some time I have an Audio issue with my MSI Z97 Gaming 5 motherboard: The motherboard outputs both the audio for the left-hand and right-hand speakers through the left-hand speakers of my audio devices.
The issue came after installing a clean install of Windows 10. I then installed most of the drivers using Windows 10 update, the only drivers I installed manually are the Killer E2200 Gigabit Ethernet Controller and Sound Blaster Cinema drivers.
I have tried to remove the Realtek HD Audio and Sound Blaster Cinema drivers and to re-install them with downloads from the manufacturer's website. I used Ccleaner to fix potential registery issues/error and rebooted my system before re-installing the drivers. I've also updated my BIOS to the latest version, but the issue still persists.
To be thorough I've screwed open my desktop to check with the motherboard manual if the cables where still in place and connected to the right ports on the motherboard, which they were. Then, I've connected the AUDPWR1 to the PSU and flipped the AUD_SW1 switch to see if that had any effect. It did not. I've also tried to switch up the connectors connected to the JAUD1 port. AC'97 did not give any power to the front audio jack, while HDAUDIO did. So the HDAUDIO is what's currently connected to the JAUD1 port. Both audio devices (headphones and speakers) do work properly on my laptop, tv and phone, so its not because of faulty audio devices.
I am currently planning on rewiring the whole system to make sure everything is connected correctly (my system needs better cable management anyways.) and most likely I will install a new clean install of Windows 10 while I am at it.
But, before I do all of that. I would like to hear your suggestions on this matter and see if I can get this resolved in a way other than re-doing my whole system.
For what it's worth I will put a list of devices and drivers with versions installed on my computer below. If there is any information missing, please let me know.
Audio Devices:
Steelseries Syberia V2
Logitech Speaker System Z906
Operating System:
Windows 10 Education 64-bits (10.0, build 17134)
Motherboard:
System model MS-7917
BIOS V1.13
Drivers:
Realtek High Definition Audio Driver Version 6.0.1.8010
Sound Blaster Cinema 2 Version 1.00.08
AMI BIOS Version 1.D
p.s. If this isn't the correct forum to post this issue, please let me know where to post it
Audio Devices:
Operating System:
Motherboard:
BIOS V1.13
Drivers:
