This is my first build and I need to make sure this would work.
Motherboard- ASUS RAMPAGE FORMULA LGA 775 Intel X48 ATX Intel Motherboard -$299.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131284
Processor- Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Retail -$239.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Memory- G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory-$144.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
GPU- ASUS EN9800GX2/G/2DI/1G GeForce 9800 GX2 1GB (512MB per GPU) 512-bit (256-bit per GPU) GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported-$559.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121239
Hard drive- Western Digital Caviar SE WD5000JBRTL 500GB 7200 RPM 8MB Cache IDE Ultra ATA100 Hard Drive-$99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136185
power supply-XION Supernova XON-800R14N ATX12V / EPS12V 800W Power Supply 115/ 230 V CUL, FCC, TUV, CE, C-tick, CB, BSMI-$189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817190016
case- XCLIO A380BK Fully Black High Gloss Finish SECC 1.0mm thickness ATX Full Tower Computer Case -$129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010
OS- Going to use Vista 64 bit
This is going to be my first build and this is what I came up with so far. Any advice or recomendations for extra cooling would help.
