MY pc is Lagging pls help
Misbah Haq
7
sorry for my english
hi,
My pc started to lag from 1 week and i cant play anygames properly i m getting 9 constant Fps in CSGO before i was getting 70+.
My pc and Web browsers is lagging cant open 3 tabs, before i can open 7+ tabs easily with CSGO running in background,but i cant even play CSGO after exiting antivirus and all other applications.
THIS PROBLEM STARTED when i was playing csgo and watching videos on TWITCH at same time and sometimes my game stops and PC shuts down and it wont restart also
I checked the problem by removing GPU,ram and when i checked my CPU fan speen in bios its 2900 and temp 50.
Pls help me tell me its my processor having the problems or motherboard or fan or ram,etc
My PC specs are
i3 540 @3.07
4 gb ddr3 ram
ATI amd 6450 1 gb card
razor 10
98
Hello there... Try to run out system optimization software. To fix the registry, corrupted directory and so on. Reset your bios to defaults. If u know to apply thermal paste open the heat sink of processor and apply the paste. Try to do system restore if there is any problem with operating system. Reinsert the rams all.. And give it a try. Its just a random diagnose test. It might work :)
Misbah Haq
7
but mate this issue is same in win xp and win 7
