Question My PC monitor won’t display correctly ?
Jan 16, 2024
Edit: I switched the 2070 super out for my old 1660. It works now. So my graphics card is scrap. Oh well lol
Hello, I need help. I was playing Elden Ring when my display blacked out. So after waiting a minute to see if it would fix itself, I turned it off by the power button. After a few seconds, I turned it back on. Now it turns on my display, the screen more or less flashes the bios icon, then the screen changes to just a few pixels in the upper left of the screen. No curser, no command prompt. Can’t get into bios. I restarted it and now it won’t show the bios at all. Just the few pixels. Please help me if you can.
Pc specs:
i7-12700k
2070 super founders edition
32gb ddr4 ram 3200
700w rosewill power supply
2tb m.2 drive
2 x 1tb m.2 drives
Nothing is overclocked
Rosewill is the brand of the PSU while 700W is the advertised wattage of the unit. What is the model of the unit and it's age?
Remove the discrete GPU from your build and hook up tot he iGPU, see if you can get into BIOS. Would be a good idea to also see what BIOS version you're on right now.
Reactions: Phillip Corcoran
