Question My PC suddenly doesn't turn on, help
Mar 19, 2020
I woke up in the morning and tried to turn on my PC but it doesn't turn on, ive tried to unplug the power hold power button for 30seconds plug it in and it doesnt work, ive tried to use my screwdriver on the motherboard to bypass the power button and it still doesnt work, what works is when I put the screw driver on the 2 pins to the left of the POWER SW, Power LED - and Power LED + and hold it there the pc turns on and doesnt beep, but only if I hold the screwdriver there, when I move it the PC turns off, nothing has been moved nor unplugged, everything is plugged and the PC is almost 2 years old,
B350Motherboard is ASUS PRIME B350-PLUS
Does anyone know something to fix this?
I have a photo showing where the screwdriver goes.
View: http://imgur.com/a/zJ4Pwtv
Thank you in advance.
