Bought a used 2.5 SATA 1TB hard drive. It came out of a Seagate Goflex USB portable HD.
http://www.seagate.com/www/en-us/products/external/external-hard-drive/portable-hard-drive
I want to buy a USB enclosure for that. The drive is a bit thicker than your normal 2.5 drives. So most on ebay a will not fit and are made for drive 500GB or less. Tried contacting Seagate, no luck. Can someone recommend an enclosure that will fit this drive?
Thanx
Thanx
