[SOLVED] Need advice on new system
s3lin1
67
Hello everyone ,
so I will be switching my current asus z170 viii ranger + 6600k to a msi z490 a pro + 10400f.
I have a sata SSD which has windows installed on it . I Have a digital licence and it's linked and activated with my microsoft account and all that. On this SSD i only have windows and some programs installed like mozilla cpuz etc.
I also have 2 HDDs which have games and all my files on them.
Do i need a clean install or can i just plug the SSD and use "perform a reset and remove evyrthing" also do i need to do anything with my HDDs? Or can i just plug them on the new motherboard and everything will work fine .
thanks for your help
Hello everyone ,
Hello
Windows is linked to your macadress, so that means in theory if you swap...
Hello everyone ,
Hello
Windows is linked to your macadress, so that means in theory if you swap mobos, you'll have to change your windows key
that said windows allows for 1 migration, use a software like produkey to extract your licence code (or any other method, google around)
you'll have to do a win install from scratch for this to work
also if you swap out a mobo a reinstall is needed anyways
your HDD's should be fine, no need to format those
Good luck
