Need advice on PC case
victor96
Hi,
I would like to know if anyone could give me some advice regarding a PC case I was thinking of buying.
I've never really heard of a brand called 3R System and came across a PC case model called r700 which comes with something called an Imon, it is on a website and is going to for a really good price like $10.
http://www.cannla.com/Auctions/470/...cessories/3R-System-R700-Black-with-Imon.html
Could anyone tell me if this is worth buying or would I just be wasting my time? Or should I just stick to brands like Coolermaster or Antec? any feedback would be appreciated cheers.
HAF 932 also has better cable management options.
But the $80 price difference might buy you something to make the whole system better, video card upgrade for example.
And the CM 690 is at least "good enough" at providing good airflow and cable management that I'd have to say getting the more expensive case won't make your system any "faster".
But the case is also the only component you have to look at day after day so your personal style choice is at least as important as functionality.
I went to the web site and looked at the case. It is a smaller case with very poor ventilation, airflow, and cooling. Cable management will also be a problem. It definitely looked like you would be wasting your time. I also checked out their terms and conditions page. There is an awful lot of fine print.
As you already mentioned yourself, you would be better off sticking with an Antec or CoolerMaster case. Buy what you like that meets your requirements.
Thanks for the feedback, I think I'm going to buy this other one I saw on the same site 3R System - R102 - Black which is only going for $1 dollar and weighs only 3.6kgs.
http://www.cannla.com/Auctions/469/...mputers-Accessories/3R-System-R102-Black.html
I mean its just a dollar what's the worst that could happen? if things go south at least I could chuck it off a building and buy a Coolermaster, cheers theramman for the links, keep you all posted.
I've built two computers with the 690 case. Lot's of airflow and space for fans. No problems fitting all of my stuff, one build was with a 4870x2. Both the 4870x2 and the q6600 have been oc'd and there are 0 issues with heat.
