Question Need assistance controlling my fan RGBs on my ABS Cyclone prebuilt from newegg
Mar 19, 2025
9
My rig and its specs
Model:
ABS Cyclone Aqua- Model number: CA14400F4060#580
  • Operating System: Windows 11 Home
  • CPU: Intel Core i5-14400F Raptor Lake 10-Core (6P+4E)
  • GPU: MSI Ventus GeForce RTX 4060 8GB GDDR6
  • Motherboard: MSI PRO B760M-VC WIFI BULK
  • RAM: Team T-Force Delta RGB 32GB (16GBx2) DDR5 6000Mhz
  • SSD: Kingston M.2 2280 1TB PCIe 4.0 x4 NVMe
  • CPU Cooler: Montech ARGB Air CPU Cooler
  • PSU: ABS 650W 80+ Gold ATX PSU
  • Case: ABS Cyclone mATX Gaming Case Obsidian (Black)
  • Dimension: 12.62" x 7.87" x 16.34"
  • WiFi: WiFi 6E
  • Bluetooth: BT 5.3
  • VR Ready: Yes
Newegg Link: Link to PC
My Issue:
Im trying to figure out how to control my case fan RGBs... instructions say that the reset button cycles colors and powers it off but it actaully just resets the PC.
I uninstalled MSI Center as i was having issues (kept giving me a buffer circle icon every 5 seconds and made the cpu spike) so i got argus monitor instead as well as openRGB, and msi afterburner...
OpenRGB is working for my keyboard, and it worked briefly on my ram, although its hit or miss and made the rgb tweak out on the tforce ram sticks so i reset it and now they are back to normal and cylcing through colors
i jsut wanna be able to control my rgb and be able to shut them off
Any suggestions?
I would advise on making sure you're on the latest BIOS version for your motherboard, then manually install the latest version of MSI's center app, then install Mystic Light to manage your RGB's. I've had to uninstall the app twice since my foray with MSI's B650i motherboard. It's annoying but after you uninstall it, reboot, then manually install the latest version, you should be fine.
To add, if you don't want any lights on it, then disconnect the RGB/ARGB lighting connector for the fans.
Moved thread from Components section to Cooling section.
I’m hoping with mystic I can control them all around and even shut them off maybe. If that doesn’t work someone told me to try signalRGB.
How do i make sure I’m on the latest bios version?
EDIT: so use revo to uninstall open rgb, do i need argus monitor? can u reccomend better CPU GPU monitoring software. DO i need MSI aferburner?
You can use CPU-Z to tell you what BIOS version you're on for your motherboard. It'll be stated under the mainboard tab. For the time being just focus on getting Mystic Light. I've been steering clear of SignalRGB since they've been hit or miss, also being a culprit of downloading and installing the wrong firmware for the platform you might be working with.
Type Control Panel in Start>hit enter>Uninstall a Program(listed underneath Programs)>remove the app you're trying to remove. Reboot the system.
Reactions: iTsDraco23
is revo ok to use for uninstalling?
I also have this small cord with two ends that came on it is this the ARGB cord that needs to be run from controller to mobo?
Photo on top my bad
I’m having the same issue. I have a similar abs prebuilt to your’s with the same motherboard and case. My case reset button doesn’t do anything and none of the rgb softwares recognize the 3 main case fans.
From a customers review from the one he bought.
Cons: This particular model will give you problems with the RGB of the fans, they are all direct to the psu and you cannot turn them off or change their colo
