Need Good value CPU but best possible Speed
Manhota
129
basically im looking for a upgrade of memoery CPU and motherboard.
my current setup is this:
AMD XP2600 OC 14x166 2340mhz. Aero 7 cooler jet.
DFI Lanparty nforce 2 Ultra Version B motherboard.
512 333mhz [-peep-] ram
Audigys sound with cambridge soundworks DTT3500.
2 X DVD 8x + - writer liteon
Thermaltake Butterfly 480watt supply 7LEDs LCDtemp
and 2 adjustable fans
Thermaltake Xaser III ALU case 4 adjustable fans with LCD temp display. 2 neons.
6800 128 Galaxy OC to 405*805 www.galaxy-hk.com
i play lot of games, but i also do a lot of video converting and editing e,t,c
what cpu should i go for next i want it fast but not stupidly priced like a £500 ($1000) p4 4.0ghz or fx55
and whats the best motherboard with that cpu plus what type of ram?
Recommendations would be gratefull thx.
AMD XP2600
DFI Lanparty nf 2U
512 333
Thermaltake B 480watt.6800 128 Galaxy
with your setup, I'd just upgrade the RAM and o/c that CPU a little more
_______________________
Whos round is it? Down that beer quick, smash my glass down, fall over the table - all rowdy and pissed
I agree, if I were you i'd get 2 512 sticks of ddr400 and run your cpu at 200x12 or even higher. There is no point in buying a new cpu and mobo yet when you already have a decent setup. Even if you got an a64 w/ mobo you'd still only be getting a 10% increase for 300+$ IMO that's not worth it.
Watch out for the <b><font color=red>bloody</font color=red></b> Fanboys!
AMD64 2800+ :: MSI Neo-Fis2r :: 1024mb Kingmax ddr400 :: Sapphire 9800pro 128mb :: 10K WD Raptor
Addicted, finally.
You dont mention your graphics card. Your system looks quite good, get some more ram, and if poosible, a better graphics card.
If you are running 2 256mgb sticks of ram now, you can keep dual channel, by buying a 512 stick, and twinning the old stuff. You can even use pc3200, but you will have to use 166 fsb.
i have a 6800 128mb 12pipline which ive unlocked all 16piplines with rivatuner its a galaxy.
i need a better cooler for my cpu if i want to oc it to 12 x 200 cpu gets unstable at 50C and the aero lite 7 jet cant keep it cool enough can you guys recommend a good cooler then thx.
AMD XP2600
DFI Lanparty nf 2U
512 333
You already got a decent CPU! Like other suggested, you might get DDR400 ram to push your FSB higher, which would increase your overall performance.
A worth upgrade would be an Athlon 64 3400+/3500+ or P4 3.4GHz to really notice a GOOD improvment is speed overall.
You might get a 90nm Athlon 64 (the 3000+) and overclock it to 2.6GHz (or higher), this might be a "cheap" solution for better performance.
This article is very interesting :
<A HREF="http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2242" target="_new">http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2242</A>
A7N8X / <font color=green><b>AMD Sempron 2800+</b></font color=green> <-- <i>Is this affecting my credibility???</i>
Kingston DDR333 2x256Megs
<font color=red>Radeon 8500 128Megs</font color=red> @ C:275/M:290
therod
basically i will not see much improvement at all if i upgrade at the moment then.
also interesting link with the .09nano technology on a amd 64bit 3000 chip, overclocked that baby out did a fx53.
im not no stranger FOOL.
I understand your situation. I'm "stuck" with my "old" Athlon 1800+ overclocked to Sempron 2800+ for a long time now. And I'm always on the upgrade or not upgrade questioning.
Basically, I always wait for the "killer" apps. I tought that FarCry was the one, but I found that my main problem was my GPU, so I wanted to change my GPU, but then I tought that I would really want a PCI-EXPRESS GPU (long term investment)... But, I really want an AMD64 and there is not any PCI-EXPRESS MB for AMD64 out yet. So, I keep waiting for nForce4 or the new VIA chipset (I personnaly prefer nForce).
And now, Half-Life 2 is almost there, maybe this game finally give me a good reason to "kill" my old tbred.
I will surely buy one of those Athlon 63 3000+ @ 90nm. By the way, if you want to upgrade for "cheap", you don't need DDR400. Athlon 64 running on DDR333 instead of DDR400 are only a few percent slower. I personnaly will only buy a MB+CPU+GPU for my next upgrade. I will only buy faster RAM if I find out that my DDR333 is really holding me back.
<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=185234#185234" target="_new">Read this thread</A>, there is a discussion about DDR333 and A64 combo!
Rod u are da man.
i am so in that dilemma shall i upgrade now or lata. with my 6800 i have no porblems in any games check out my 3dmark scores:
3dmark05 4090 sumthing
http://service.futuremark.com/compare?3dm05=122636
3dmark03 10305
http://service.futuremark.com/compare?2k3=3214780
But its Video conversions video editing stuff which is a pain in the neck it makes my blood boil making a DVD which takes 3 and a half hours to convert.
i will upgrade now if a processer does a conversion in 10mins flat for a full 4700mb dvd from avi.
i OC my cpu to 14.5x 166 but not always stable if i touch the fsb cuz ram suks ass so i need to upgrade from 512 anyway.
another dilemma is i brought a galaxy 6800 like 2 months ago if i get a new pro and motho i hope it comes with a agp slot in the future. do u guys think agp will still be about in a years time?
http://www.overclockers.co.uk/acatalog/Corsair_XL.html
Wow! You will not upgrade soon!
If your really need that much Video Processing power, you whould consider buying a P4, they are a bit faster than AMD at doing this, but in games they are slower...
Are you doing DivX to MPEG2 conversion? If you do this, you should consider D/L original MPEG2 of your movies on Bit Torrent (you don't loss quality and don't need to do conversion).
AGP will be there as long as you keep a MB with AGP slot on it! It's not necessarly a bad move to buy high-end AGP card today if you have a future-prood system. In my situation, it would be a bit weird to get an AGP card when I know that I will buy a PCI-EXPRESS motherboard in a few months!
But, I personnaly think that X800/6800 are the last high-end AGP card we will see on the market. The next GPU generation will surely be PCI-EXPRESS only.
Could some of you comment of my system ratings
Athlon Xp 2500 OC to 2.2 (400bus)
Soyo dragon Kt600 Running at 400 bus
3 X 512mb Corsair (value select) 400mhz running Ram
200 Gb 100 ata Hitachi
60 GB 100 Ata Maxtor
on board sound
Tnt 2 Riva 32mb Video (4 years ol')
I'm planning on upgrading video to a
Prolink (Pixelview in europe) FX 5200 with 128mb 128 bit.
Btw, anyone who has this card please commment.
Your rig is good!
1. The FX5200 is one of the WORST GPU ever made. To me, it's the worst GPU nVidia have ever made. Never buy one unless you pay less thant 5$ for it.
2. If you want to buy a LOW-END card, buy a 64Megs version, 128Megs is useless on these card, because the GPU is not powerful enough. The main bottleneck in LOW-END GPU is the GPU itself not the amount of onboard memory.
My cheapest recommendation for DX9.0 GPU in order :
1. Radeon 9600 PRO 128Megs
2. Radeon 9600 XT 128Megs
3. GeForce FX5700 128Megs (Radeon 9600 have better Image Quality)
A bit more budget :
1. Radeon 9800 PRO 128Megs
2. GeForce FX5900 XT 128Megs
Even more budget :
1. GeForce 6800GT
2. Radeon X800 PRO
If you really want to save money and don't need DX9.0 support, the GeForce TI4200 is a good choice, but for the long run it will become obsolete when games will require DX9.0 minumum to run!
I recommending following items
A64 3400+ (Newcastle, 2.4 GHz, 512k L2 cache)
MSI K8N Neo Platinum
2 x 512 MB Crucial Ballastix DDR400
<A HREF="http://www.foood.net" target="_new">FOOOD's Icons</A>
<A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig</A> & <A HREF="http://geocities.com/spitfire_x86/benchmark.html" target="_new">3DMark score</A>
Many people here like Crucial Ballastix, but I have no personal experience with either Crucial or Corsair
This kind of struck me as odd, also another reason why people are far more confused then necessary, and then wonder why they get bad results.
<b>It is important to pay attention to the ram recommendation here.</b>
Quote from SpitfireX86.
Quote from Manhota
is crucial better than kinston or corsair ram, if so what should i get?
Just out of curiosity why in the hell would you recommend a product you have no experiance with based off of other peoples oppinions, when most of us are aware that when someone says that something is better it is usually just their oppinion. Its Hearsay ROFL
Yes that was a shot.
Doesnt that sort of stuff bring your reputation, and validity into question?
Naw im just playing, i would have to be a real immature DICK to mean all that shiz.
However it seemed a good opportunity to point out that this is the typical sort of response we see on this forum, and how ridiculous and unnecessary it all is.
Thanks for being a good sport.
<b><font color=blue>Co-Founder and Administrator of Toms Hardware IRC</font color=blue></b>
<b><font color=red>
Server: hub1.oddnet.net
Channel: #Tomshardware
</b></font color=red>
Excuse me, are you just looking to pick up a fight? If you don't like this, then just leave the forums. Because this is how it works.
There's no one in this forum who has used all of the stuff he recommends/thinks good. Everybody of us depend on reviews and other people's experience to judge a product.
Become a wise person and start asking retailers for the real realiable info.
heya Spitfire;
I said i wasnt serious, not only that but you didnt even comprehend what i was doing, but since you wanna get all rilled up about it and make a scene, and be rude then i will be rude as well, what is the level of your comprehensive abilities, that of a 2nd grader?
See how rude that is? thats what im talking about, i bet you still missed the point i was trying to make, i will spell it out for you.
I was using my own rude response as an exmaple of the typical response of certain people on this forum that make it unpleasant at times, i just used you as my punching bag for the example, what you said was irelevant other then it was a starting point for my point, it wasnt even a shot at you personally, again it wasnt even aimed at you...did you even read the post or did your face turn red with anger, and you saw what you wanted to see, re-read it, i think you will get a very different read the second time around ROFL, oh and next time atleast try and comprehend what was said before you fly off the handle.
Oh and btw, you think just because you have more posts then me that you deserve to be here more then someone with less posts, hahahahaha, ive been posting here for years, as long as you have, just because i dont have 5000 posts doesnt mean im any less a part of this community then anyone else, or less valued, there are people here that litterally have 4x the amount of posts you do which would according to the way you are thinking and behaving you are a friggin newbie compared to them, but i doubt they see others with a low post count as newbies, the amount of posts you have mean jack shiz, i dont see Crashman saying things like "STFU" or "if you dont like it you can leave" or other immature shiz like that, its not how many posts you have but what you know period, so get off your high horse, what you did in your response was just another example of the behavior im talking about.
<b><font color=red>
Sorry if I have offended you. BTW, now you've brought the "postcount" thing. Did my rude reply had anything to do with postcount or "seniority".
I think the original poster who asked for help doesn't expect us to have personal experience with all of our recommended products. How much he values our opinions is enitirely upto him. Your post didn't contribute anything useful.
Again, sorry for my rude post.
heya spitfire;
Well its not that my post didnt contribute to anything usefull, it just didnt contribute to anything usefull on this particular post.
btw i appreciate the gesture of the appology. I also appologize for using you as a punching bag for one of my examples, but as afore mentioned it wasnt aimed at you, instead through you, i can easily see how that could be misconstrued.
<b><font color=red>
I know that I will regret this but; not only am I a newbie to this forum, but I am a newbie period. I have been posting questions right and left, and getting very useful input "Most of it anyway". From a newbie point of view this is the kind of thread that runs new people off. So I guess if that is the goal, then keep on with the tension! I make important decsions based on the advice that I receive here. This is not the first forum that I have posted questions in, but it is by far the very best. I hope things dont get so serious that the quality and the humor goes to crap! Or is it Crappness? Im still confused about the difference of the two!!!!!!!!!!!! Yall do have a good thing going here, keep it real.
