need help building very cheap gaming PC skyrim on medium or above
aaron96528
9
I'm trying to build my first gaming PC and I need help and advice to buy very cheap parts but that are still amazing enough to run medium or high setting and thats upgradable later on. Looking to buy piece by piece over time what to start with and what can be left for last.
Aaron, before anyone can provide an accurate build, there are a couple questions we need to be answered.
First, what is your budget? What is included in the budget?
I'm going to go ahead and make a point. Cheap builds and high settings typically don't work.
Very cheap is usually 200-300
It depends. If you can get most of your stuff from ebay (Core 2 Duo E6850, GTX 660, some 250gb hdd, decent used EarthWatts PSU, some Dell Mobo, 4gb of ddr2) then you might be able to get to high settings @ 720p.
question? why ddr2 not 3?
was thinking of $350 a micro atx mid tower build amd processor and 4-8gb ram 4 if i can upgrade to 8 later and want it upgrade-able later on i know its alot but ive been searching
AMD FX 4-Core Black Edition FX-4300 (thinking of this one)
OS: Windows 7-8.1 (purchased)
Storage: WD Caviar blue 1Tb(made up my mind on this one)
PSU: CX450 (thinking of it)
Motherboard: ASRock 970M PRO3 (maybe)
Need help with compatibility
