Need help choosing a hardware raid card
miketsmith
5
I would like to set up a raid 5 on my system for a little bit of redundancy and a speed increase. I was thinking of setting 4 drives into a raid 5, but I hear that it is a good idea to use a raid controller card to do this (as calculating parity can flood the bus, and not give you the performance you would like)
I see there are many options available through sites like newegg, but the price points range widely from 50 dollars to 2000 dollars.
Can someone help me find a suitable card for 4, (or if not much more expensive) 8 sata 3.0Gbit or 6.0Gbit interface drives? Thanks much!
If you are looking for a controller supporting up to 8 SATA 6Gb/s drives and willing to spend about $600, I would recommend Areca ARC-1880i. This card has two SAS connectors, comes with two SFF-8087 cables for connecting up to 8 SATA hard drives and has very good performance.
The beauty of this hardware raid controller is driver-less, as far as system concern it sees the raid as a SINGLE hdd
with transfer rate of 230~250MB/s
So if you need more speed just add another one and create a raid0
With 2x SPM393 cost at $240.00, you can create a RAID50 (10x HDD) and it can transfer about 450~495MB/sec with email notification
Of course if you want faster than add another controller...
There is NO hardware controller 8ports PCIe that costs below $400.00
This is very good raid card, you may able to get about 300MB/sec on raid5 with 4 drives (7200rpm)
