I wanna make a build that I can Stream games with solid 1080p 60fps and that works well for editing and gaming too.
The games I play aren't usually very heavy, if they are tho I don't mind having to put them on low settings. The GTX 1060 3gb that I have now isn't that bad at all. To me the most important is that I have a great stream quality and my editing software works smooth.
For gaming the only thing I need is enought FPS for my 144hrz monitor.
But I wanna make a new build, I'm not keeping the GTX 1060 because that goes to my brother.
Utilizing discounts from black friday what would you guys recommend as a build. I can spend from like 500 to like 800 euros, maybe 900 if it's really necessary for what I want. But on the graphics for example, I think I prefer to not get a much better one and leave it for later (in case that doesn't affect the streaming or editing).
I have currently an i5 - 6500 and a GTX 1060 3gb. Some of the games I play the most and would like to stream would be Overwatch and Minecraft for example, nothing crazy.
I like newegg and they have a really nice discount on this processor Ryzen 7 2700x: https://www.newegg.com/global/pt-en/amd-ryzen-7-2700x/p/N82E16819113499?Item=N82E16819113499
Is this one good enough for great streaming? I don't have any experience with AMD, always had Intel so I'm not sure what I'm getting into. But I actually have a monitorwith Freesync, and that one is staying with me.
From my research I think I understood that I need a pretty good cpu, I can save a bit on the graphics card, leave that for the future maybe, need like 16gb at least for the editing.
I don't care about things looking pretty. I wanna save as much as possible on things that don't affect performace substantially. I've actually seen some people without cases, is that safe for the components?
Thanks, can't wait for your help!
So I was playing around in part picker and I ended up with this:
https://pcpartpicker.com/list/vmVH27
I have no clue how to choose a motherboard and how important it is for the performace of the pc.
For the storage I need an SSD for sure but I dunno the difference between the small ones that go on the motherboard and the big ones and if it's worth the price or not for what I need. For the graphics I was a bit lost too. The case is actually the same one I bought for my current pc.
Since there's no massive discounts on graphics maybe I should wait until they show up.
