Need Help to create a DOS Boot Partition ?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello
I want create Two partition on my hard disk
one with WindowsXP and One with Win 98 DOS Boot system
I just create its and if I change with FDisk the active partition (with CD
bootable), every thing is Ok :
I can boot corectly with XP partition or Win 98 Dos Partition (come from a
Bootable diskette)
BUT if I use a Boot.ini file on my XP partition like this :
[boot loader]
timeout=3
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professionnel"
/fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="MS-DOS" /fastdetect
the XP Boot work fine BUT MS-DOS don't work fine
My screen show an error like this
{dddd}System32\hal.dll doesn't exists ...
Someone could be help me to fine the solution of my problem
thank for your help !
How To Create a Multiple-Boot System in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;306559&Product=winxp
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
"azerty" wrote:
| Hello
| Bootable diskette)
| [boot loader]
| timeout=3
| [operating systems]
| /fastdetect
You need to start over. The DOS partition should be the First one, then XP
in the next partition.
Please see this Microsoft article on multi-booting
http://support.microsoft.com/KB/306559
Il faut tout-a-fait recommoncer. (Excuser mon Francais)
What happens now, is that the boot files are being initiated from your first
partition and so you get the error.
Bon chance !
Maurice N
MVP Windows - Shell / User
"azerty" wrote
> Hello
> Bootable diskette)
> [boot loader]
> timeout=3
> [operating systems]
> /fastdetect
azerty wrote:
> Hello
> Bootable diskette)
> [boot loader]
> timeout=3
> [operating systems]
> /fastdetect
The simplest way I've found to dual boot between Win9x/Me and WinXP
would be to partition your drive(s) roughly as follows:
C: Primary FAT32 Win9x/Me/Legacy Apps
D: Extended NTFS WinXP/Modern Apps
Adjust the partition sizes according to your actual hard drive(s)
size and the amount of space you'd like to allocate to each OS and its
applications.
Create the partitions using Win9x's FDISK so you can enable large
disk support (FAT32). (No need for 3rd party partitioning
utilities/boot managers and their frequent complications.)
Install Win9x/Me first, being sure to select "C:\Windows" (or
D:\Windows, if you prefer) when asked for the default Windows
directory. When you subsequently install WinXP, be sure to specify
"D:\Winnt" (or "D:\Windows," "C:\Winnt" as referred/applicable) when
asked for the default Windows directory, to place it in the other
partition. The WinXP installation routine will automatically set up a
Multi-boot menu for you. The default settings for this menu can be
readily edited from within WinXP. NOTE: If you elect to place
Win9x/Me on the "D:" drive, you'll _have_ to leave the "C:" drive as
FAT32.
This method can be adapted to using 2 physical hard drives by
placing the boot partition (C:, which still must be FAT32) and either
of the operating systems on the Primary Master hard drive, and the
second operating system on the second hard drive.
It is also possible to have a 3rd partition for shared
applications, but it would be necessary for such a partition to be
formatted in the common file format (FAT32). The applications would
also have to be installed into each OS (to ensure proper system file
placement and registry updates), one at a time, but the bulk of the
program files could be located on this common partition. I do not,
however, actually recommend doing this as, if you were to uninstall
such an application from one OS, you may not be able to gracefully
uninstall it from the second OS, having already deleted crucial
installation data during the first uninstall action.
Just about everything you need to know (URLs may wrap):
http://support.microsoft.com/support/kb/articles/Q217/2/10.ASP
http://www.microsoft.com/windowsxp/pro/using/howto/gettingstarted/multiboot.asp
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
The first active partition is the second partition.
The second partition is C:, because it active.
This line is referring to a XP type operating system, which is causing the
hal.dll error.
The line should read:
c:\="MS-DOS"
Ron Sommer
"Maurice N ~ MVP" <maurice@mvps.org> wrote in message
news:u3nkBPcqFHA.1336@TK2MSFTNGP11.phx.gbl...
> XP in the next partition.
> first partition and so you get the error.
> Bon chance !
> Maurice N
> "azerty" wrote
>> Hello
>> CD
>> a
>> Bootable diskette)
>> [boot loader]
>> timeout=3
>> [operating systems]
>> /fastdetect
Thanks a lot for your help, ron. With your advice, I understood better the
boot.ini file and its syntax.
I try do this on my computer but I need too restore the BootSect.DOS file on
my active partition with this example and DEBUG.EXE DOS Program
http://tweakhomepc.virtualave.net/dual/bootsectdos.html
C:\="MS-DOS" use implicit the binary file c:\BootSect.DOS to start the
computer, BootSect.DOS is a copy of boot sector of the target partition I
need ....
In fact, my real configuration is :
Partition 1 : NTFS, XP Pro
Partition 2 : FAT32, no system file, just for data ans save Ghost file ...
Partition 3 : FAT (only 8 Mo size), DOS partition (Win98, create with a
bootable diskette) I want use on it a Ghost software
Partition 4 : NTFS, XP Pro (a save of Partition 1, for SOS if something work
wrong on partition 1, necessary If i want read important file on NTFS
partition 1)
I want config my computer to restore very easy in the next time when
"partition 1" shutdown (Virus, XP bad patch, bad installation of software,
etc. ...)
Maurice N. say me the first partition must be in DOS mode ("merci pour le
"bonne chance", il en faut !!) , But it is a lot of work for me to change my
configuration, moreover I would be sure it is not just for use automatic
process of Windows XP installation. Moreover, I don't use XP standard CD
installation (My computer (a notebook toshiba) use a repair CD disk with a
ghost file ...)
Now, If I use the "partition 3" option, computer start but Command.Com don't
start !!
I have this message :
Enter name of Command Interpreter (for example, C:\Windows\Command.com)
c>
and nothing command work fine (dir, copy, cd, etc. ...)
I try to copy it on Partition 1 but this tips don't work too
NB : If I change with FDISK the active partition to Partition 3, every thing
work fine >>> Partition 3 is a "good" partition ...
thanks a lot for your help
best regards !!
"Ron Sommer" <rsommer@nospam.ktis.net> a écrit dans le message de news:
%23crVjHdqFHA.3680@TK2MSFTNGP15.phx.gbl...
> hal.dll error.
> c:\="MS-DOS"
> Ron Sommer
>> Bon chance !
>> Maurice N
>> "azerty" wrote
>>> Hello
>>> CD
>>> a
>>> Bootable diskette)
>>> [boot loader]
>>> timeout=3
>>> [operating systems]
>>> /fastdetect
I just find the solution !!
in fact the System DOS partition must be the first of FAT16/32 partition on
the disk
in my case, the first FAT16/32 est partition 2, so even if I boot on
Partition 3, Command.Com must be on partition 2 !!
>>> I am going to switch order between partition2 and partition3
Thanks everybody for your help !
"azerty" <azerty@aaaa.fr> a écrit dans le message de news:
u$2tgW9qFHA.2880@TK2MSFTNGP12.phx.gbl...
> on my active partition with this example and DEBUG.EXE DOS Program
> need ....
> work wrong on partition 1, necessary If i want read important file on NTFS
> partition 1)
> etc. ...)
> my configuration, moreover I would be sure it is not just for use
> automatic process of Windows XP installation. Moreover, I don't use XP
> standard CD installation (My computer (a notebook toshiba) use a repair CD
> disk with a ghost file ...)
> don't start !!
> c>
> thing work fine >>> Partition 3 is a "good" partition ...
> best regards !!
>> the hal.dll error.
>> c:\="MS-DOS"
>> Ron Sommer
>>> Bon chance !
>>> Maurice N
>>> "azerty" wrote
>>>> Hello
>>>> CD
>>>> from a
>>>> Bootable diskette)
>>>> [boot loader]
>>>> timeout=3
>>>> [operating systems]
>>>> /fastdetect
