[SOLVED] Need Help to Recover my data from my External HDD
dr.strango
20
4
525
Hey All,
I happened to buy an External Hard Drive(Transcend 1TB USB 3.1 Gen 1 StoreJet 25M3S SJ25M3S Rugged External Hard Drive) from a local dealer a year back. I have not used that drive that much, sparsely 10-15 times till date. I just used it to backup my photos and stuffs from my phone in that hard drive. And i don't have any other backups. . Yesterday when i tried to connect that Drive, it suddenly says "You Need to Format the disk in drive before you can use it". I am scared af right now. I tried to reconnect it few times but it doesn't work and says the same thing. Another thing, i have never mishandled my device ever and yes it has not fallen off from anywhere.
Have anyone ever had faced a similar issue previously ? If yes, then please help me get out of this mess. I just don't want to lose any of my data.
P.S. I just researched a bit about this HDD in amazon and it doesn't have much good reviews so please show me a ray of hope anyone.
Thanks in advance !!!
Amazon Link of the External HDD: https://www.amazon.com/Transcend-TS1TSJ25M3S-Information-StoreJet-External/dp/B07B4CJ4KS?th=1
If you are interested in recovering the pictures etc and it's not working through the USB then you'll need to remove the drive from the case. Be careful though.
I gave up using HDDs in internal or external drives - I lost too many videos etc.
I recommend changing to an SSD based external drive when you can.
@SteveRX4 : I could try that but i don't see any opening actually. No screws seen . So, need to refer google once and see if i can do that .
@USAFRet : Hey, i know i should have kept some more backups but i don't think this is the right time to discuss such things. I would rather welcome a generous suggestion rather than such rants atm. Thanks.
