Hi everyone,
Have followed this site for a long time but this is going to be my first post.
So I have a custom built rig built 4 and a half years ago. I am a 3D/Graphic Designer and use 3d/2d softwares and also some casual gaming.
My graphic card is a AMD Radeon R9 290X Sapphire Tri-X OC Edition 4Gb. It worked well until this past Sunday. The display on my screen won't turn on although the CPU was running. Did a lot of research on what could be the problem and finally called a technician. He deduced that the HDMI port on my card was faulty and plugged in the cable to my onboard HDMI port. I asked him if the card will work with the DVI port and he said I would have to check it out with a DVI connector and VGA Cable. Otherwise I would have to buy a new card.
So guys is there any possibility that the DVI port might work, or do they all stop working simultaneously?
One more question, incase I have to buy a new card, I have selected Nvidia Zotac GTX 970 AMP Omega 4GB version. Is that an equivalent to my current card?
Cheers and sorry for the long post.
My rig is as follows :
I7-4790 3.6ghz
16 gb ddr5 ram
Asus Z97 D3h motherboard
I7-4790 3.6ghz
16 gb ddr5 ram
