Question Need help with connecting Xbox One S controller over Bluetooth
Jan 13, 2019
12
Hi, I have an Xbox One S (Bluetooth enabled) controller that I am trying to connect to my computer with over a Bluetooth connection to play Minecraft Bedrock Edition on Windows 10. Most guides that I've seen seem to use an in-built Bluetooth radio inside of their PC, while I have an external Bluetooth 4.0 radio dongle. I have successfully been able to connect my controller to this dongle (the light on my controller stays solid white and the manager says the connection was successful), but it doesn't do anything once I load up Minecraft Bedrock. Any help would be appreciated.
Thank you!
Did you go through the guide here and also the troubleshooting link https://support.xbox.com/en-US/xbox-on-windows/accessories/connect-xbox-one-controller-to-pc ? There is also this thing if you can't get your adapter to work with it https://www.bestbuy.com/site/micros...-for-windows-10-black/6253924.p?skuId=6253924
Yes, I looked through that guide, but I had to do it slightly differently because I don't have built-in bluetooth. I know that I am able to connect to it because the Game Controller app (the one built-in to Windows) responded to the buttons and joysticks. It still doesn't work on Minecraft Bedrock though.
