Hi Guys, Need some major help here I cant figure out this problem.
Heres the settings I have used.
Bios 0502
FSB - 1512 - Ram 810
Vcore - 1.5
Dram - 2.11
HT - Auto
NB - 1.44
SB - Auto
Enhanced C1E Disabled
LDT Frequency - 5X
With These settings I have passed the Latest Prime95 (25.6) Small FFT Tortue Test with 13 Hours and 23 minutes no Errors.
Then I try Tortue Test - Blend
At This Position it Stops - 2nd Main Test (8K) - Number 10 in the test.
The Computer completly shutsdown. Doesnt Even restart.
So I changed the following...
HT - 1.38
SB - 1.5
So that they are not on auto
And Set the LDT Requency to 3X
It runs through Blend again... The Same Exact position - 2nd Main Test (8K) number 10 in the test... the computer shuts down again. I have tryed to mess with memory timings...
Only Thing I can think of is my ram is OCZ PC6400 800MHZ Ram (stock 4-4-4-15-1T timings 2.1v) ... I have it on 2T and 1T doesnt work, causes blue screen hardware failures or freezes. Does anyone have any idea ... or can anyone help me?
forgot to add.. I have ran through memtest before and it was fine, even with timings of 4-4-4-12-2T 2.1v.. Anyone have any idea?
I have also tryed these settings and the same result happens - always the 8k Test number 10. Also tryed Bios 0402.
HT - Auto
NB - 1.56
SB - Auto
HT - Auto
NB - 1.44
SB - Auto
HT - 1.5
NB - 1.5
SB - 1.5
Right now I am trying HT - 1.5, NB - 1.5, SB - 1.52 it froze, I know my top settings are right, it passed small fft's for 13hours 30mins i have pic and everything. I dont see why blend would be failing. Memtest is also fine.
Bios 0502
Vcore - 1.5
Dram - 2.11
HT - Auto
NB - 1.44
SB - Auto
LDT Frequency - 5X
HT - 1.38
SB - 1.5
HT - Auto
NB - 1.56
SB - Auto
HT - Auto
NB - 1.44
SB - Auto
HT - 1.5
NB - 1.5
SB - 1.5
