Specs -
CPU - i7 10700K
COOLER - NZXT Kraken X61
MOBO - Asrock B560 PRO4
RAM - Corsair Vengeance LPX 32GB @3000
GPU - Gigabyte RTX 3060 Ti OC
M.2 SSD - WD Blue SN550 NVMe 1TB
SSD - Crucial MX500 1TB
SSD - Crucial MX500 2TB
PSU - Corsair HX1000
I have 2 possible faults from recent upgrades but not too tech savy to find the culprit. I built my first pc close to a year ago when i got a 2060 and didnt have a single problem with it or my components and ended up selling the 2060 and upgrading to a 3060Ti 3 weeks ago then upgraded my psu from a corsair HX850i to a Corsair HX1000 from umart since it was 7 years old.
I cant remember if the 3060ti was having the issues with my old PSU since the performance increase from the 2060 to the 3060Ti was so much that i didnt notice but the last week or so its been having serious issues.
First issue is now the VGA light on the mobo comes on and stays on for alittle bit then turns off during boot after all the other PSC lights turn off so it thinks in the GPU as do i but it could be the psu.
Second issue is in most games the GPU only hits 30-60% usage which in some games its fine until it stutters or has to alot to load and makes it dip in fps, some but very few still run at 80-100% usage but with less fps then before.
Third issue that confuses me and makes me think it could also be the new PSU is when on restarts and shutdowns the power indicator light on the GPU that is above the 6+2 pin connector turns of for abit then off.
Forth issue is when the screen goes black for alot longer then it ever has when it gets into the desktop screen also if i turn off one of my monitors it also flickers longer then usual and it some other cases it does the same.
Another issue that makes me think its a PSU issue is sometimes on restarts/boot ons all the leds in the PC on all components get dimmer and flicker sometimes aswell.
Everything is seated and connected the same exact way as to when i had the Hx850i and RTX 2060 in the pc so i have no clue if its the GPU or the PSU or both.
Things ive tried. Ive updated my bios, used DDU on the gpu, changed the PCIE lanes from auto to gen 3, tried non xmp and xmp on the ram, tried overclocking and underclocking the gpu, tried different cables from the psu to the components and even tried using the PSU in single and multi rail mode. All things resulted in no changes to the issue.
Dont know if i should RMA the GPU or PSU or both.
Ive got screen shots of HWmonitor, ingame and Hwinfo64 logs
Pics of Ark running with all fresh cables running on single rail mode. - View: https://imgur.com/a/fdOGvBv
Ark running with the first cables i used when i got the new PSU running on multi rail mode. - View: https://imgur.com/a/FBsUFpr
Squad Running on single rail mode - View: https://imgur.com/a/KPM2ffb
Logs - https://mega.nz/file/f2g32ZAK#DR_e5lWWpaN2GibQuU5daZnVyjSoDFBftBDlEIDizCI
CPU - i7 10700K
