So my question is this, is it dangerous for the CPU if you start your newly built PC just to check if the BIOS is updated for Intel 13th gen without the mobo having the 13th gen BIOS update?
Tomorrow I will receive a delivery with Intel Core i7-3700KF and Gigabyte Z690 Gaming X DDR4. I've done research and many say you need to update the BIOS. Can I assemble the whole computer and check if it works or should I run a USB flash installation first without assembling everything?
