Need some help deciding a few parts,GPU, for my 1st PC (gpu, psu).
omar954
109
Ok so here are the basic stats:
■e8400, i plan to oc maybe to 3.4ghz?
■p180 case, fits my needs but i was wandering if i could fit a 2 9800gtx a fan?
■ocz sli ready ddr2 800mhz ram, plan to oc to 1066mhz
■780i p5n-d board, sli ready
Porblems:
■for gpu i might go with 8800gts then sli later or go with 9800gtx and sli later or go with 9800gx2. can someone help me decide btwn these 3 options and explain the diffs plz? is the gx2 just 2 gtx?
■im really at a loss for the psu, i don't understand the concept of 12v rails, do the plug in to the mobo, the gpu, the cpu or what?why do i need multipe 12v rails? PLZ help! :(
ilovebarny
523
ok for your first build your doing great. i suggest going with the 9800gtx ( overclocked versions are better obliviously) now with a psu. 12v rails are what most of your system runs off of ( ie. cd drive, hard drive, gpu, ect) bascily you want at lest 18amps on a 12v rail. a good psu will have 20 amps or more on the 12v rail. multiple 12v rails are good cause you are more likely to have severle PCI connectors which is what you connect to your gpu's. http://www.newegg.com/Product/Product.aspx?Item=N82E16817189022
that psu has good rails but its way overkill for you. you want something around the 700-900 watt psu for your system. http://www.newegg.com/Product/Product.aspx?Item=N82E16817815003
that would work better.
omar954
109
Thanks for explaining the PSUs for me, tho im still a bit confused, do i need a 12v rail for every cd-drive, cpu, gpu? and i still need to know if the gpus will fit in p182 with a fan.
omar954
109
Could i get something like this in a p180?
dagger
Splendid
Mar 23, 2008
5,624
Get 9800gx2 instead. At $270, it cost less than dual 9800gtx, same as dual g92 8800gts, and does not require a crappy, overpriced, underperforming Nvidia chipset motherboard. A $100 p45 board will outperform the 780i while costing half as much.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128345
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131333
Gx2 performance is slightly below those dual cards due to underclocking, but it's only by 50mhz, at 600mhz, but you can either oc it yourself or buy the factory oced version (675mhz) for $10 more.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133231
Benchmarks (stock 9800gx2):
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=13
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=14
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=15
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=16
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=17
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=18
http://www.anandtech.com/video/showdoc.aspx?i=3341&p=19
omar954
109
daggger, that is really gonna change my plans up alot, but what psu will i use with such a crazy card?? and will it fit in the p180?? (refer to pic)
Oh yeah, as for the video card the 9800GX2 is really just two 9800GTXs in SLi on a single PCB, much like the Radeon 4870X2 (but not as fast as the 4870X2 :D ). I'm not to fond of nVidia based boards right now, but the 780 based boards are much better than the 600 series. Anyway If you can afford it, go with the 9800GX2. If not then get a 9800GTX like this
EVGA 9800GTX
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339
or
XFX 9800GTX+
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150314
As for the GX2, it's best to get the factory overclocked versions for a little bit more like dagger suggests.
omar954
109
im so overwhelmed.....
so if i go with the p45 since the 780i sux i cant go sli (only one pciex16) so i will have to go 9800gx2. thats cool but its 10.5 inches and i dont think it will fit in my case witha fan, which i think i will need cuz people say this card is HUGE. also i need a ower supply..... i dont know what to do!!!!!!!!
Let me assume that the primary purpose for this build is for gaming.
Read this article, and think about where you fit among the options. It will depend on what games you will play, what resolution you will use, and how much you value good gameplay. Read this and see where you are:
http://www.guru3d.com/category/vga_charts/
For the most part, it is the vga system that determines how good a game plays. In general, a high end single card like the GTX260/4870/9800gx2 will play anything out there nicely.
In my opinion, SLI or crossfire(the combining of two vga cards) is a poor value if you can be satisfied by a single strong card.
You pay more for the motherboard, and more for a more powerful psu today. If you exercise your upgrade in the future, you will be paying for a second card that is closer to being obsolete. It is better, I think, to plan on selling your old card at upgrade time, and replace it with the next best thing.
I think I would buy a E8500 up front for $20 more, and forget about overclocking. Unless your game is cpu bound like FSX or supreme commander, you will not get a big boost out of overclocking.
C2D cpu's are not very sensitive to ram speeds. Your FPS will be perhaps 1-2% better with faster ram. Very much not worth it to me. Ram is cheap, and 4gb is a good idea. Heres why:
http://www.corsairmemory.com/_appnotes/AN804_Gaming_Performance_Analysis.pdf
I would get a 4gb kit of DDR2-800 ram in a 2x2gb configuration from a quality vendor.
The Nvidia chipset motherboards seem to have more issues than the Intel P45 motherboards. Both have their fans though. If you want SLI you need a Nvidia board, if you want crossfire, you want an Intel board. If you want neither, then either board will do.
Don't go cheap on the PSU. A good quality vendor can save you some headaches. Corsair, Seasonic, PC P&C, Antec are good. Look for a tier 2 unit or better on this list:
http://www.xtremesystems.org/forums/showthread.php?t=108088
As a simple rule, any quality psu with two pcie 6 or 6/8 pin connectors will run any single vga card out there.
Most psu's out there are really single rail units. Their output is divided into several 12v. rails to limit the amps delivered on a single rail. Some consider it a safety issue. It really is a non-issue.
A psu will have a number of cables which you plug into the motherboard and other devices. A cable may have several connectors on it. This will be the sata connectors, and the 4 pin molex conectors which are used for several things like fans. A good psu recommendation is the PC P&C silencer610 for $89.99 after rebate.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005
It will run any single vga card made, or will power a sli configuration with two lesser cards like the 8800GTS.
The P180 is a good quiet case. You can fit two of the longest cards out there like the GTX280 or 4870X2. The number of hard drives might be reduced to 3 or 4. I don't like front doors, so I might pick the Antec 300 instead.
---good luck---
dagger
Splendid
Mar 23, 2008
5,624
That's a common misconception. 9800gx2 is the same length as 9800gtx. See pictures.
http://www.newegg.com/Product/ShowImage.aspx?CurImage=14-130-339-05.jpg&Image=14-130-339-03.jpg%2c14-130-339-04.jpg%2c14-130-339-05.jpg%2c14-130-339-06.jpg%2c14-130-339-07.jpg%2c14-130-339-08.jpg%2c14-130-339-09.jpg%2c14-130-339-02.jpg&S7ImageFlag=0&WaterMark=1&Item=N82E16814130339&Depa=0&Description=EVGA%20GeForce%209800%20GTX(G92)%20512-P3-N871-AR%20Video%20Card
http://www.newegg.com/Product/ShowImage.aspx?CurImage=14-133-231-S03&ISList=14-133-231-S01%2c14-133-231-S02%2c14-133-231-S03%2c14-133-231-S04%2c14-133-231-S05%2c14-133-231-S06&S7ImageFlag=1&Item=N82E16814133231&Depa=0&WaterMark=1&Description=PNY%20GeForce%209800%20GX2%20VCG98GX2XPB-OC%20Video%20Card%20-%20Retail
omar954
109
Yo u have made my day, no week, no 10 days of researching. and u did it all in one paragraph. i love u so much.... its not even funny!!!!!1
