[SOLVED] Need some help wrapping up my build!
BokehBG
7
Hello!
I just got back from the US where I bought some of the more portable parts (CPU, GPU, RAM, and SSD). So what remains would be the CPU cooler (which I didn't get from there since it is pretty much the same price in here), mobo, PSU and case. So here is what I got
I7 9700K
EVGA RTX 2080 SUPER
32 GB RAM 3200MHZ Corsair
1 TB NVMe M.2 SSD Samsung
For the remaining ones I'm thinking:
Noctua NH-D15
AUROS Z390 PRO Wi-fi
FD Meshify C - DARK TG
Seasonic Prime Ultra Gold 650W
So basically for the first four, I can't change them at this point. For the others, I am open to suggestions. Though in my country the choices are more limited. Thank you
I'm planning on buying a 1440p 144hz monitor. And also I've been looking at a few similar builds and many people recommend a 750W+ PSU. What do you think?
1440P/144hz would be a good pairing for the build. As for the PSU the Seasonic 650W you picked is enough for the build & overclocking so no worries.
