Need some help.
rickstar
26
I am currently looking at new computers ive found one that is pretty cheap and looks like it is very good so i was just wondering what you all think. Its off ebay but its close to me so i can look at it and pick it up
Pretty much for gaming and general use.
http://www.ebay.com.au/itm/AMD-Phenom-II-X6-1090T-6-Core-Gaming-PC-Windows-7-Pro-/130433549805?pt=AU_comp_dekstop&hash=item1e5e7205ed#ht_5958wt_1135
CPU AMD Phenom II X6 1090T 3.2GHz 6-Core Processor
Motherboard Gigabyte GA-880GM-USB3 with AMD 880G + SB710 Chipset
Video Card AMD Radeon HD6870 1GB 2x DVI/1x HDMI/2x Mini DisplayPort (Asus|Gigabyte|Sapphire|XFX)
Hard Drives 2Tb (2000Gb) SATA II 64MB Cache Hard Drive
Memory Kingston 8Gb DDR3 1333MHz Dual Channel Memory ( 4 x 2Gb DDR3 )
Optical Drive 22x Dual Layer DVD Burner SATA Drive
Power Supply CoolerMaster eXtreme Power Plus 600W
Case Thunder Storm 3000 Case with See Transparent Side Window/2x Blue LED Fans/All in One Card
Reader
Unit Dimension 455 (L) x 185 (W) x 478 (H) mm
Card reader All in One Internal Multi Card Reader
USB 2x USB3.0/2.0 @ back | 7x USB2.0/1.1 (3 @ front/4 @ back)
Audio HD Audio 2/4/5.1/7.1-Ch
Network Cards Ethernet network adapter (onboard 10/100/1000Mbps) RJ-45 LAN Port
Firewire 1 x IEEE 1394a ports at the back panel
eSATA Port 1 eSATA-2 Port @ back
Keyboard/Mouse Port 1 x PS/2 keyboard or PS/2 mouse port @ back
and im also looking at this one, its cheaper but without a g card but you can get upgrades and with a good g card upgrade still about the same price
http://www.ebay.com.au/itm/INTEL-i7-2600K-3-4GHZ-GAMING-COMPUTER-PC-1TB-8GB-HDMI-/300573460154?pt=AU_comp_dekstop&hash=item45fb9306ba#ht_4202wt_1135
Just add a video card... gtx 560 ti, gtx 560, 6870
http://www.mwave.com.au/sku-16010561-Antec_Three_Hundred_Tower_Gaming_Case_Mid_ATX_Tower_Black_Steel_9x_Drive_Bays_SS $59.99 inc. GST
Antec Three Hundred Tower Gaming Case
http://www.mwave.com.au/sku-34040663-Antec_520W_High_Current_Gamer_Power_Supply_80Plus_Bronze_135mm_Fan_SLI_&_Cro $85.00 inc. GST
Antec 520W High Current Gamer Power Supply - 80Plus Bronze
http://www.mwave.com.au/sku-28023477-MSI_P67A_C43_B3_Motherboard_LGA1155_Dual_DDR3_2133(OC)_Intel_P67(B3)_Chipset_4x_ $105.20 inc. GST
MSI P67A-C43 B3 Motherboard
http://www.mwave.com.au/sku-19010218-Intel_Core_i5_2500K_3_30GHz_Quad_Core_Socket_LGA1155_95W_TDP_4x256KB_L2_6MB_L3_C $219.99 inc. GST
Intel Core i5 2500K
http://www.mwave.com.au/sku-37140683-Corsair_4GB_Single_Module_Memory_DDR3_PC3_10600_(1333MHz)_CL_9_9_9_24_240_pin_DI $35.00 inc. GST
Corsair 4GB Single Module Memory - DDR3 - PC3-10600 (1333MHz) - CL 9-9-9-24 - 240-pin DIMM (CMV4GX3M1A1333C9)
http://www.mwave.com.au/sku-22040155-SAMSUNG_Spinpoint_F3_HD103SJ_1TB_7200_RPM_32MB_Cache_SATA_3_0Gb_s_3_5%22_Inte $59.00 inc. GST
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.mwave.com.au/sku-17040381-Samsung_SH_222AB_BEBS_Internal_22x_DVD_Burner_SATA_OEM_Black $22.00 inc. GST
Samsung SH-222AB/BEBS Internal 22x DVD Burner - SATA - OEM - Black
Total: $586.18 inc. GST
http://www.mwave.com.au/sku-39090362-Microsoft_Windows_7_Home_Premium_SP1_64_Bit_DVD_Single_Pack_OEM_(GFC_02050) $105.00 inc. GST
Microsoft Windows 7 Home Premium - SP1 - 64-Bit - DVD - Single Pack - OEM (GFC-02050)
http://www.mwave.com.au/sku-42060694-Sapphire_Radeon_HD_6870_Video_Card_GDDR5_1024MB_256Bit_VRAM_900_4200MHz_Clock_PC $195.00 inc. GST
Sapphire Radeon HD 6870 Video Card - GDDR5 1024MB 256Bit VRAM - 900 / 4200MHz Clock - PCIe 2.1 - DVI, HDMI & Display Port - CrossFireX Ready - DirectX 11 & OpenGL 3.2 (11179-09-41G)
http://www.mwave.com.au/sku-42051044-MSI_GeForce_GTX_560_Twin_Frozr_II_Video_Card_GDDR5_1024MB_256Bit_VRAM_810_4000MH $210.60 inc. GST
MSI GeForce GTX 560 Twin Frozr II Video Card - GDDR5 1024MB 256Bit VRAM - 810 / 4000MHz Clock - PCIe 2.0 - Dual-Link DVI & Mini HDMI - PhysX & SLI Ready - DirectX 11 & OpenGL 4.1 (N560GTX TWIN FROZR II)
Neither one really shines though as being great.
Phenom II:
The PSU on the phenom II is crappy, otherwise it seems like a reasonable build.
Although the HDD is missing brands and stuff so can't really tell much about it.
i7 build:
The i7 build, well there is no mention of what manufacturer the PSU is from.
I'm actually quite concerned that the PSU is even worse in this build than it is in the phenom II build.
The case seems passable, but is nothing fancy.
You would need to add the $40 for a P67 mobo, since would be silly getting a i7 2600k without a mobo to overclock it with.
Also 1600Mhz memory would be a sweet spot performance wise.
Then as you pointed out you would have to spend $180-260 for the graphics card.
560Ti would be very nice for you.
Conclusion:
The i7 would be more powerful. That's for sure.
In both cases you probably need to add the $100 for the OS to get win7 home premium 64-bit.
If those places are close by, they would probably let you pick custom parts for a system and then put it together.
Both have their ups and downs, but neither really shines through as being overly good.
Switching the PSU to something a little better from Antec, Corsair, Silverstone, Seasonic or XFX the AMD build would win just because more is told about what's in it.
If they are willing to do a custom build and the costs are not massive, i can list what you should look for.
CPU: i5 2400(non-oc) or i5 2500k(oc)
MB: Asrock, Asus, Gigabyte and MSI
- if you want to Crossfire or SLI in the future one with at least 2 16x PCIe connectors running at 8x minium. P67/Z68 based boards
- if you want to overclock P67/Z68 based boards - and you will need an after market HSF for the CPU
- if you don't intend to overclock or crossfire or SLI H67 based boards will do
Mem: 2x4GB of 1.5V 1333Mhz mem for H67 boards, 2x4GB of 1.5V 1600Mhz mem for P67/Z68 based boards
Corsair, Gskill, Kingston and Mushkin generally for brands but others will do
GPU: brands don't mean too much: 6850/6870/6950 from AMD for gaming in a reasonable price range, GTX460 1GB/560/560Ti from Nvidia
Case: something with decent airflow and space for graphics cards. Such as Antec 300. The one in the phenom build didn't look bad either.
PSU: depending on if you want to SLI/Crossfire and which graphics card you chose
~500-550W for single cards.
650W for dual 6850
750W for the other dual card solutions.
From Antec, Corsair, Silverstone, Seasonic or XFX.
HDD: 1TB 7200rpm SATAII HDD will do fine. Samsung Spinpoint F3 1TB would be the best.
DVD: pretty much any 24x DVD burner will do from Asus, Lite-On, Sony, Samsung etc.
And windows 7 home premium 64-bit for OS
You should be able to get the above computer without the OS from about $900 and up depending on the selections.
Then i'm sure they will slap you with some surchage for putting it together.
The builds that previous posters listed are great, but if you are set on going the prebuilt route, the 2600k + video card would stomp the Phenom and for a lot less. Not to push the subject unnecessarily, but do you have reservations about building your own system?
hmm well if anyone would like to suggest a build for me these are the places i shop at.
http://www.gamedude.com.au/'
http://www.umart.com.au/ (select the 3rd location which is closer to me)
probly under $1600 would be good, i want a really fast computer but aswell with excellent graphics and a nice looking case :)
CPU: Intel Core i5 2500K Processor LGA1155 3.3GHz CPU $215.00
HSF: Noctua NH-D14 CPU Cooler $108.00
MB: ASRock Z68 Extreme4 Z68 4xDDR3 3*PCIex16 GBL RAID DVI HDMI DS $198.00
Mem: G Skill 8G(2x4G)DDR3 1600Mhz PC3-12800 CL8(F3-12800CL8D-8GB) $95.00
GPU: Sapphire ATI HD6950 2GB GDDR5 PCI-E $268.00
HDD: Samsung 1TB Spinpoint F3 SATA II 7200RPM 32M $58.00
DVD: Asus DRW-24B3LT 24x DVDRW SATA LightScribe $34.50
PSU: Corsair HX-750 ATX Power Supply, 140mm Fan $189.00
Case: Corsair Obsidian 650D Black Mid Tower Case with Window $218.00
OS: Microsoft Windows 7 Home Premium 64bit OEM $94.00
Total: 1477.50 + 134.32 GST = $1611.82
Not sure if monitor was needed or not, or if you like the look of the case or if OS was needed or not, I included it just in case.
But monitor can be fit in if needed by downgrading the PSU, MB, CPUcooler and possibly case.
Currently everything in it is pretty much top of the line stuff, so you shouldn't be disappointed.
6950 can be replaced with 560Ti if Nvidia strikes your fancy better.
That machine should play games at 1920x1080 at high or very high details at sufficient FPS. And to crossfire/sli all you need is a 2nd graphics card.
