W Wingspun Reputable Jun 29, 2019 4 0 4,510 Jun 29, 2019 #1 Motherboard ASUS Z390-E CPU Intel core i5-8600K GPU Msi 1070Ti RAM Hyper X 2/8Gb 2666MHz DDR4 Whenever I try to turn on my new build it won't post on my monitor and a yellow DRAM light turns on. Please Help.
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jun 29, 2019 #2 Try leaving single RAM installed and testing each RAM slot on board. Upvote 0 Downvote
W Wingspun Reputable Jun 29, 2019 4 0 4,510 Jun 29, 2019 #3 That worked perfectly thank you so much for your help. Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jun 29, 2019 #4 You're welcome. Are there RAM slots on board not working? If yes, then it might be a bent pin in the CPU socket. Upvote 0 Downvote
