Hi Tomshardware users,
I need your help with a task. First of all here is my system that i just bought:
AMD Phenom II x4 Black edition
Rosewill FUTURE case
Gygabite 6950 1gb
8gb ram (4x2)
SSD
asus m5a97 motherboard
i didnt buy powersupply since i already had RAIDMAX "RX 730SS" however i dont have the cables that came with it since i bought this long time ago and i didnt keep the extra cables with it. So i ran into this problem when you have to plug 2 pcie 6pins in to your graphic card: 1) Wire is not long enough. 2) There is only 1 PCIE cable.
My idea: to get a splitter, This to be exact: http://www.newegg.com/Product/Product.aspx?Item=N82E16812200935
Out of my power supply i have bunch of 6pin cables coming out, out of which only 1 is pcie, but all are same length so none which are long enough to reach to my graphic card. So my idea of this 6pin pcie splitter would work great if it works. or will it not be enough power or something? I do need your input guys!
I need your input if you think it would work or i need your suggestions on what you think i should try.
Gygabite 6950 1gb
8gb ram (4x2)
SSD
