In my BIOS I have the ability to set up a fan curve. I want to do it there because using MSI dragon center has made it so if my monitor turns off for power reasons, so does my RBG keyboard... and then even though Dragon Center is set to ignore my keyboard, it wipes the RGB settings of my keyboard and I have to load them back on with Corsair's portal if I want keyboard back lighting again. So yeah, that's got to stop.
The problem is I've never set up PWM fans before ever. My BIOS gives me the option to use the CPU core temps, or the CPU socket temps, as well as a few other MISC temps. Which should I use for which fans? I have 2 front and 1 side intake fans, as well as 2 top and 1 rear exhaust fan. The pairs of fans are controlled via splitters. All fans are the same black Noctua fans, save my CPU fan, which is a standard tan Noctuan fan, and is STUPID FRICKN LOUD (even though Noctua is supposed to be quiet). I don't think there's a solution to making my PC stop sounding like a god damn P-51 Mustang taking off every time I simply open facebook... But there might be. Mostly I just want to know what I should set up for my case fans and CPU fan so everything works well and I can haz backlight again.
Hardware wise I am running a Ryzen 5 3600 with a nice aftermarket cooler on a Micro-Star B550-A Pro motheberboard. I've got a GTX 980 SI GPU in there too. Not sure if that's necessary info for case fan stuff.
