D
Deleted member 2920117
Guest
During the past few days I've been trying to get my younger brother's new computer to work, to no avail. I've tried to include as much relevant information as possible below.
Components:
During this installation process, your PC reboots several times. As soon as it shut down and tried to start again, the following happened:
We have:
Some interesting things:
Components:
- Motherboard: Gigabyte Z690 GAMING X DDR4
- CPU: Intel i9 12900k
- CPU cooler: BeQuiet! Pure Rock 2 Black
- Power: Sharkoon WPM GOLDZERO 750W
- HDD: Seagate IronWolf ST4000VN008 (4TB HDD) & INTEL 730 480GB (SSD)
- Ram: Corsair VENGEANCE RGB PRO SL 16GB (2x8GB) DDR4 DRAM 3200MHz C16 Memory Kit\
- Videocard: Asus geforce rtx 3070 TI OC
- the motherboard LEDS turn on, but turn off a few seconds later. However: the VGA-LED stays red.
- The keyboard's LED's (fancy gaming keyboard) turn off
- There is no input going to the monitor
- No response whatsoever: LED's on the RAM and Motherboard stay on, fans keep spinning. Seems frozen. Stays like that until power is removed/ power button pressed for 5s.
- If we click on restart (start menu), it looks like it shuts down, but when it 'boots' again we don't see the PC start, instead we see the black screen, no signal etc as described above. LED's on the Motherboard and RAM stay on.
- What works is turning it off completely (removing power cable/ power button for 5s) and then start the PC again. If we do that, it boots fine
- If we shut down (start menu), it shuts down fine. Evertything including fans and LED's turn off completey. However, if we start the pc again, we have the black screen again.
- If we force shut down (pressing power button 5s) after the black screen, it boots fine afterwards.
- If we do a auto restart (during updates, during installation, when changing something in the BIOS) it doesn't restart either: the fans keep spinning, RAM LED's stay on, VGA LED as well. Long-pressing the power button and then starting again is the only solution.
We have:
- Done all windows updates, including drivers. Via Windows Update, via Gigabyte's App and manually via the Gigabyte website
- Checked the device manager: all components are recognized and working fine
- Manually flashed the BIOS to its most recent version (was 4, now 8b), no success
- Reset the BIOS using the pins on the motherboard, the reset button and by removing the battery. Each time we got a confirmation that it has been reset, however, no changes.
- Tried different harddisks (4TB HDD and 480GB SSD) but no success
- Removed the GeForce external card and used the iGPU (Intel UHD 770) and tried another older videocard as well (Asus DUAL-RX460-2G), same issues with all three GPU's
- Tried changing the RAM, we tried two sticks in A2 and B2, two sticks in A1 and B2, and only using one stick of 8GB
- Gone through all of the advanced options of booting (safe mode, UEFI boot mode, repair mode etc), all going to either the black screen forcing us to reboot, or not doing anything.
- Taken apart and rebuilt the entire PC twice, double-checking every cable/connection
- Changed the default GPU in the bios to the internal GPU, to the PCI slot (if using an external card) and we even turned off the iGPU, no difference
- Removed and reinstalled the GPU drivers multiple times via the device manager/safe booting
- Ran the Intel Processor Diagnostic Tool, no errors
- Turned off the secure boot option in BIOS (it was Enabled, now Disabled, no differences)
- During a succesful boot, the VGA LED sometimes turns off, sometimes it stays on
- Sometimes the time to go from turning the PC on to being able to login to Windows was rather long (30sec)
- Sometimes the time between logging in and actually having everything ready in the taskbar (shortcuts etc) was rather long (30sec). Disk was at 100% according to Task Manager.
- The BIOS froze twice when we were browsing to the BIOS update file via QFLASH in BIOS. Note: this is NOT during an installation.
