[SOLVED] No ghosting monitor
LORYT699
Commendable
Apr 6, 2022
190
6
1,595
Hi, I have an msi optix g32c4 and it have a HEAVY ghosting, I think the problem is the red or the blue, the green look fine.
Some one know some 32" monitor fhd or 2k with no ghosting(122hz)?
Anyway does displayport is better then hdmi for ghosting?
This is quite common problem with VA screens.
Get IPS screen or OLED (if you can afford it).
The problem is that not everybody have the same problems on this monitor!
Some have only backlight bleeding and some others like me have an horrible ghosting or also some say they have nothing of that.
I ve seen also some monitor(IPS) that say they have ghosting too.
Can you suggest some model?
Could be fault of the cable? a dp could help me?
You can try changing response time settings for the monitor (with buttons on monitor).
Those have impact on levels of ghosting.
already done and it does a little, but still an eavy ghosting.
I ve tryed with maneging some settings but the solution is not applicable to an everyday use.
There are some profile that reduce a lot(almost none remaning)but they look soo bad and I can see every pixels, the images are not smoth at all or I ve tryed playing with brightness and contrast but the results are the same, I could not use it in night time cause it would be like having a beacon in the eyes
