Archived from groups: microsoft.public.win2000.active_directory (
More info?)
Andrew,
I found very quickly what settings you probably mean in Computer
Configuration \ Administrative Templates \ System. One of the settings
simply adds additional information in the three screen that you mentioned.
The other one, however, completely removes these screens. This is the one
that is most likely set in your environment.
The one that completely removes these screens is the 'Disable Boot /
Shutdown / Logon / Logoff Status Messages'. This is most likely the culprit
The other one that I mentioned above is the 'Verbose vs. normal status
messages' setting. This simply adds additional information in the status
message. However, it goes by very quickly ( as you might expect ).
I do not know what happened with me reading the initial post. I somehow had
in my head something completely different.
Cary W. Shultz
Roanoke, VA 24012
Microsoft Active Directory MVP
http://www.activedirectory-win2000.com
http://www.grouppolicy-win2000.com
"Cary Shultz [A.D. MVP]" <cwshultz@mvps.org> wrote in message
news:%23XuE6NqqFHA.908@tk2msftngp13.phx.gbl...
> Andrew,
> Where did you find these settings that can be configured? I have a little
> test lab here ( WIN2000 AD with WIN2000 clients ). I will gladly check it
> out for you so that you do not need to worry about mucking up the
> production environment.
> Cary W. Shultz
> Roanoke, VA 24012
> "Andrew Story" <andrewDOTstoryATjameswalkerDOTbiz> wrote in message
> news:e6HG8JiqFHA.4088@TK2MSFTNGP15.phx.gbl...
>> Hi Cary,
>> Not too sure about that one, just had a look in the BIOS and couldn't see
>> any options regarding this.
>> Just in case anyone wasn't aware of this, I did find a GPO setting that
>> can
>> be enabled that disables all those screens though : ) but alas it was not
>> configured/enabled so not sure what it is : / no viruses either the
>> machines are clean as whistles. Any other ideas ladies/gents?
>> news:%23EEWfEfqFHA.3304@TK2MSFTNGP11.phx.gbl...
>>> Isn't there a BIOS setting that controls this?
>>> Cary W. Shultz
>>> Roanoke, VA 24012
>>> news:%23dsSGeXqFHA.3304@TK2MSFTNGP11.phx.gbl...
>>> > Guys/Gals,
>>> > Strange one that has just started hapenning on our network (Win2k AD,
>> all
>>> > clinets win2k pro).
>>> > All of a sudden, we no longer have the 3 screens before the
>>> > ctrl+alt+del
>>> > one
>>> > that advise, applying sec, preparing network conns etc. Also at
>>> > logoff
>> we
>>> > no longer get 'saving you settings'.
>>> > Is there a gpo setting that a member of staff could have
>>> > inadvertantley
>>> > modified to alter this behaviour? Or could it be an MS update?
>>> > TIA
