Question No SATA power cables ?
anonsky
68
7
4,535
I have an old Acer proprietary, I basically salvaged everything in it for my new PC, I have since gave that computer to my sister so I'm trying to get it back and running, the problem is, the PSU inside this thing has no SATA power cables. I remember it had a weird six pin to sata power cable but I think I threw it away or just lost it.I'll provide the picture of the header but I don't remember exactly how the adapter itself looked like. Whenever I try to look for a six pin to SATA power cable I only really get six pin PCIE to SATA cables. I know I can just buy a m.2 ssd but I'm a bit broke rn.
Edit: There are no molex cables either. I was wondering if I should buy a fan hub and then get a pwm to sata cable but im a bit scared that they might fry from too much power
I have an old acer proprietary
It would help us twofold if you were to tell us what the model and SKU for your Acer prebuilt is. Perhaps the harness you're referring to can be narrowed down per the model and SKU of your prebuilt.
Perhaps this would work;
https://pt.aliexpress.com/item/1005005461184959.html?gatewayAdapt=glo2bra
? It looks like the harness should plug onto the motherboard's highlighted connector.
https://www.ebay.co.uk/itm/275191205851
Looks like it to me.
Moved thread from Components section to Prebuilt & Enterprise section.
Show, what are available connectors coming out of PSU.
Fan connector doesn't provide 5V power required for SATA drives. Stupid idea.
