Hi community
So i have a desktop PC with the following specifications:
Ryzen 5 2600
GTX 1050 TI
AMD A320M-S2H V2
with 8GB RAM
I used it for almost a year to be fine. But recently, i experienced having no signal on my monitor. I observed that it is booting up properly since I hear the beep sound and the numlock indicator lights up. I was even able to shut it down manually by pressing ALT+F4 after 3-5 minutes. At first i thought that my HDMI cable is just loose cable. My GTX1050 TI has a DVI and HDMI slots. I have a VGA only monitor, hence I use adapter(HDMI to VGA) to connect it to my PC. I was able to borrow a DVI to VGA adapter and tried it and it is still no signal.
I connected my PC using the HDMI to VGA to my monitor and turned it on for like 3-5 minutes and still no signal. I tried connecting the HDMI to VGA adapter (without connecting it to the monitor) while the DVI to VGA adapter is connected to PC and monitor then the display appears. If I remove the HDMI to VGA adapter it will now work fine and I can even restart the computer and check the bios settings during startup.
However, when I shutdown my computer. I will start over again and have the same problem of no signal.
Troubleshooting that I tried are the following but it still failed.
I would really appreciate your answer guys. This PC is becoming unreliable to me.
Thank you very much in advance.
Ryzen 5 2600
GTX 1050 TI
AMD A320M-S2H V2
with 8GB RAM
- Reformat using the windows 10 recovery
- update my bios
- buy new sets of adapter
- Connecting to a different monitor
- removing my GTX 1050 TI, (does not work since my Ryzen 5 needs GPU to work on motherboard).
