i just got a new case <A HREF="http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=72998" target="_new">this one</A>
the only thing that have been changed is the case/PSU, and a new 9800 pro, everthing else in there is the same stuff as before, which all worked before i did the upgrade.
Windows boots up fine, and everthing works execpt for no sound. I'm using the onboard audio, this may problems are probablt due to me not wiring up the case to the mobo properly.
the case comes with no instructions, on how to attach the mobo to the case the front headphone/Mic ports are not wired correctly.
my mobo is <A HREF="http://www.ecsusa.com/products/l7vmm.html" target="_new">an Elite Groups L7VMM</A>
my mobo's manual say:
i have found the SPK1 bit fine, but my case doesn't have the cables specified above. it has cables labeled:
Mic VV
GND
Mic Data
2x cables labed: Ear Left
2x cables labed: Ear Right
the cables from the fount speaker/mic ports appear the be bundled together, i have no idea where to play what anyone have any ideas?
even with these problems i cannot see why this would stop the sound working from round the back. (my front USBs don't work but the back work fine). i have tried upadting my Mobo Drivers to no avail.
anyone have any suggestions?
right now i'd just settle for the sound just working from round the back (i can live without the front audio port).
My Specs:
Elitegroups L7VMM
AlthonXP 2100+
512Mb Ram
Radeon 9800 pro
Windows XP.
Mic VV
GND
Mic Data
My Specs:
Elitegroups L7VMM
AlthonXP 2100+
512Mb Ram
Radeon 9800 pro
Windows XP.
