[SOLVED] Noob PC builder, XMP turned on to run at 4800 Mhz but actually running at 2400 Mhz
May 10, 2022
Hello all,
I am a noob PC builder who just built his first PC. I went for top of the line components as I am starting out in software development, enjoy gaming recreationally, and am interested in trying my hand at video/music editing and other trades that require high computing power.
Despite having turned XMP on, I am still only getting the original 2400 Mhz out of the box functionality and am not sure what the issue is. So far I have entered the BIOS several times, enabling and disabling XMP. I have also updated the BIOS to the most recent state as provided by GIGABYTE. Not sure what left to do to try to get the 4800 Mhz I paid for.
A list of the main components used in question below:
CPU: AMD Ryzen 9 5950X (link to manufacturer site)
Motherboard: Gigabyte X570S AERO G ATX AM4 Motherboard (link to manufacturer site)
Memory: XTREEM DDR4 DESKTOP MEMORY (link to manufacturer site), 4 x 8 GB (I bought two of these 2 x 8GB sticks of RAM, yielding 4 x 8GB identical sticks of RAM.)
- Specifications:
SeriesXTREEM
Module Type288 Pin Unbuffered DIMM Non ECC
Frequency4800 Mhz
LatencyCL 20-28-28-48
Capacity8GB X 2
Data Transfer Bandwidth38,400 MB/s (PC4 38400)
Voltage1.5 V
Dimensions48(H) x 134(L) x 9(W)mm
Please help me figure out where I went wrong! Thank you in advance.
Hello all,
CPU: AMD Ryzen 9 5950X...
For the sake of relevance, can you state what BIOS version you're on at the time of writing? Are you seeing the speeds mention in CPU-Z? If so, 2400MHz showing up in DRAM frequency, memory tab, times 2 = 4800MHz
BIOS version is F4a, here is the link to the BIOS versions offered by GIGABYTE for the X570S Aero G motherboard: link.
As for CPU-Z, it appears the opposite affect is happening (1200 MHz showing up in DRAM frequency, memory tab, times 2 = 2400 MHz). I am unable to attach the screenshot I have taken as this website has identified it as spam and the text file is ridiculously long, so here are the important/relevant parts of it:
Chipset
NorthbridgeAMD Ryzen SOC rev. 00
SouthbridgeAMD X570 rev. 51
Bus SpecificationPCI-Express 4.0 (16.0 GT/s)
Graphic InterfacePCI-Express 4.0
PCI-E Link Widthx16 (max 16x)
PCI-E Link Speed16.0 GT/s (max 16.0 GT/s)
Memory TypeDDR4
Memory Size32 GBytes
Channels2 x 64-bit
Memory Frequency1199.7 MHz (1:12)
Memory Max Frequency1600.0 MHz
CAS# latency (CL)16.0
RAS# to CAS# delay (tRCD)16
RAS# Precharge (tRP)16
Cycle Time (tRAS)39
Bank Cycle Time (tRC)55
Command Rate (CR)2T
Uncore Frequency1199.7 MHz
Memory SPD
DIMM #1
SMBus address0x50
Memory typeDDR4
Module formatUDIMM
Module Manufacturer(ID)TEAMGROUP Inc. (7F7F7F7FEF000000000000000000)
SDRAM Manufacturer (ID)SK Hynix (AD00000000000000000000000000)
Size8192 MBytes
Max bandwidthDDR4-4806 (2403 MHz)
Max JEDECDDR4-2400 (1200 MHz)
Part numberTEAMGROUP-UD4-4800
Serial number01048A69
Manufacturing dateWeek 02/Year 22
Nominal Voltage1.20 Volts
EPPno
XMPyes, rev. 2.0
AMPno
JEDEC timings tableCL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #110.0-11-11-25-35 @ 766 MHz
JEDEC #211.0-12-12-27-38 @ 833 MHz
JEDEC #312.0-12-12-29-41 @ 900 MHz
JEDEC #413.0-13-13-31-44 @ 966 MHz
JEDEC #514.0-15-15-35-49 @ 1066 MHz
JEDEC #615.0-16-16-37-52 @ 1133 MHz
JEDEC #716.0-16-16-39-55 @ 1200 MHz
JEDEC #817.0-16-16-39-55 @ 1200 MHz
JEDEC #918.0-16-16-39-55 @ 1200 MHz
XMP profileXMP-4806
SpecificationDDR4-4806
VDD Voltage1.500 Volts
Min Cycle time0.416 ns (2403 MHz)
Max CL20.0
Min tRP11.50 ns
Min tRCD11.50 ns
Min tRAS19.75 ns
Min tRC31.37 ns
Min tRRD5.75 ns
XMP timings tableCL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #120.0-28-28-48-76-n.a @ 2403 MHz (1.500 Volts)
DIMM #2
SMBus address0x51
Memory typeDDR4
Module formatUDIMM
Size8192 MBytes
Serial number01048A4D
EPPno
XMPyes, rev. 2.0
AMPno
XMP profileXMP-4806
Max CL20.0
Min tRP11.50 ns
Min tRCD11.50 ns
Min tRAS19.75 ns
Min tRC31.37 ns
Min tRRD5.75 ns
DIMM #3
SMBus address0x52
Memory typeDDR4
Module formatUDIMM
Size8192 MBytes
Serial number01048A52
EPPno
XMPyes, rev. 2.0
AMPno
XMP profileXMP-4806
Max CL20.0
Min tRP11.50 ns
Min tRCD11.50 ns
Min tRAS19.75 ns
Min tRC31.37 ns
Min tRRD5.75 ns
DIMM #4
SMBus address0x53
Memory typeDDR4
Module formatUDIMM
Size8192 MBytes
Serial number01048A68
EPPno
XMPyes, rev. 2.0
AMPno
XMP profileXMP-4806
Max CL20.0
Min tRP11.50 ns
Min tRCD11.50 ns
Min tRAS19.75 ns
Min tRC31.37 ns
Min tRRD5.75 ns
Hello all,
- Specifications:
SeriesXTREEM
Frequency4800 Mhz
Capacity8GB X 2
Voltage1.5 V
There's a couple things that could be going on... first thing may be pedantic but worth repeating: DDR4 is double data rate so 4800 is the transaction rate, the actual clock speed is 2400Mhz. Many utilities report out the clock speed, not the transaction rate, so you have to clear that up first.
Second: 4800 is a very high memory overclock. It will almost definitely require some tweaking, not just setting XMP (or DOCP depending). At the very least you'll probably need to de-sync the IF. Probably also set a manual DRAM voltage much higher than you think necessary, at least at first until you get stable operation and you can find the lowest voltage that it will stay stable. And all this assumes the IMC of your specific CPU is even capable of 4800Mtps data rates: as always you're at the mercy of the silicon Gods with these things.
Reactions: lmcintosh623
