Hi all, I'm in the market for a new laptop that needs to have a lot of cpu cores and I stumbled upon a Lenovo one which seems pretty good with an Amd ryzen 5700h (8C16T). The main issue for me here is that it has only 8 gb of RAM at 3200 MHz, out of which 4 gb is soldered to the motherboard, meaning I can upgrade only the 4 gb stick in the slot (only slot).
The question is than if I should upgrade the slotted one for a 16gb for example and lose the dual channel effect? I've read Ryzen cpu's work better in dual channel, but would you feel that the increased memory outweighs that lose?
The laptop is intended mainly for physics simulations, including software such as Matlab and COMSOL Multiphysics, with a need to be able to have 3D visualization (I've heard the onboard graphics is pretty solid for this cpu).
Thanks in advance
Thanks in advance
