Hello, i am going to build a new pc. Here are the specs: CASE: NZXT H5 Flow MB: ASUS TUF GAMING Z790-PLUS WIFI soc 1700 DDR5 Z790 ATX 90 CPU: Intel Core i7-13700K CPU cooler: NZXT Kraken X53 RGB or NZXT Kraken X63 RGB? GPU: ASUS TUF Gaming GeForce RTX 4080 16GB OC Edition RAM: Kingston FURY Beast DDR5 64GB kit 5600MHz CL40 2x32GB Black PSU: MSI MEG Ai1300P PCIE5 1300W SSD: 2x Samsung 980 PRO 2 TB
Here is my question, as i am worried about the i7 13700k temps, i dont know if it would be better to either, buy the nzxt kraken x63 aio (which is 280mm) front mount it and use 2x 120mm nzxt fans on top and 1x 120mm nzxt fan on the back of the case, or buy kraken x53 aio (which is 240mm), mount it on top of the case and front mount 2x 140mm nzxt fans and mount 1x nzxt 120mm fan on the back of the case. The fans that i will be using are nzxt f rgb fans.
I previously already bought and installed the 140mm fans in the front of the case, for the top mount radiator config as i thought that would be better option, but afterwatching some videos i am concerned.
Thanks
Thanks
